![]() | Home > LPG > LPG, is it worth it? |
l322novice Member Since: 15 Jan 2016 Location: South Posts: 32 ![]() ![]() ![]() |
HI all, we ran out of LPG the other day. What with the snow etc, our local garages didn't have any, so we had to run our 4.4 BMW M6-whatever car on petrol. I put £40 of Tesco Momentum in, the range on the computer said it would do 212 miles before running out (may have been a little more, it doesn't matter and the computer would have been the same if I'd have put normal Tesco fuel in as it's not to know). I got some LPG later on and filled up for just over £53 (not quite 80 litres for a 100 litre tank, I think about 76 litres and it was 67p per litre) and we get around 200-250 miles out of that. It's got me thinking.....is it actually worth running it on LPG or is my maths completely out? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1361 ![]() ![]() |
Dont go buy what the computer says its a guesstimate only , should achieve an approximate saving of 40% when running lpg after the conversion has paid for itself , if you bought it already converted your saving straightaway |
By poxy autocorrect |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3172 ![]() ![]() ![]() |
One of our P38's had a sequential multi point kit on it when I bought it so I've been running it on LPG.
Dano0404 Member Since: 28 Dec 2017 Location: Uk Posts: 44 ![]() ![]() |
I run on lpg my computer says I get 19mpg but when worked out tank to tank it’s closer to 13mpg. Mine dose the same when I fill up with petrol but you won’t get near that many miles. |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 394 ![]() ![]() ![]() |
Definitely worth it...
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3214 ![]() ![]() ![]() |
If you work it out as Pence per mile, then you get a fair comparison across all fuel types and car models.
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 340 ![]() ![]() ![]() |
I filled up today in Walsall @ 50ppl and went up the M6 to Bolton and then Blackburn and sat at 70mph (and 50 in the 10 miles or so roadworks) with some town driving returning via the same LPG station and I did 225.5 miles using 61.4 litres. This works out to be 40mpg pro rata or 13.6ppm. (£0.50ppl vs £1.20ppl) so I’m pleased with that.
Hi all and thanks for the replies. I was just going on the range the on-board computer was telling me we'd get from the petrol I put in against what we get from a tankful of LPG (and her ladyship driving the massive 1/3 mile to work).
Omg Member Since: 27 Apr 2017 Location: Devon Posts: 5 ![]() ![]() ![]() |
I run a 4.2 V8 supercharged RR and I would love to have LPG at the prices you quote. I live in North Devon and there is only one station (BP) that sells LPG and it is 79p litre. When I go online to check prices out of curiousity it is always the most expensive I can find. Almost worth driving to Plymouth or Exeter (an hour each way) where you can get it for less than 50p! |
The best site I’ve found for finding LPG sites and prices is https://www.filllpg.co.uk/ Current:
Sabbsy Member Since: 10 Nov 2018 Location: Chorley Posts: 39 ![]() ![]() ![]() |
I previously had a Grand Jeep Cherokee on LPG and hit continuous problems including i.e. car acting as a kangaroo, do the current LPG systems run smoothly on range rover or is that still underlying issues?
Got lpg on mine about 20k miles ago
Thanks dingg1. You got 4.2, 4,4 or the 5.0 ? |
