Home > Technical (L322) > A couple of TDV8 questions |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
I found that it spoiled my enjoyment of driving the car.
3rd Mar 2018 9:52am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2487 |
I found the smoke embarrassing and causing lack of acceleration on my 3.0 D4 before I did the mod. I almost only ever planted the foot jumping into 100 kph traffic from a stand-still and the misfiring combined with the smoke-screen was totally unacceptable so I had the 4.4 done as part of the purchase deal. As I wasn't prepared to do the 4.4 fix myself, it was going to be costly post purchase. |
3rd Mar 2018 11:20am |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 518 |
Well, I took a 4.4 for a test drive yesterday and was unable to provoke smoke despite a few excursions well above 2500rpm. It is difficult to be certain because of the privacy glass in the rear windows but I'm pretty sure there was no sign of smoke. I also checked the belt was sitting true on the idler and as best as I could tell, it was.
5th Mar 2018 8:03am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
if you ring a JLR dealer with the VIN number they will look on Topix and see if the service history is on file...
5th Mar 2018 9:08am |
Thanks Craig - you will be my first port of call if I do pull the trigger
5th Mar 2018 9:21am |
Mike, if you want to PM me a VIN, i can check for you if that helps sir |
5th Mar 2018 9:24am |
That's very kind - I shall take you up on that now! |
5th Mar 2018 9:26am |
