Home > Technical (L322) > Loose dip stick?
ije44
United Kingdom 2007 Range Rover Vogue TDV8 Barolo Black
Loose dip stick?
Hello all,
I popped the bonnet today just for a look around as I do occasionally.
There was a decent splattering of oil around the dip stick area caused by the dip stick being out about 2-3 inches.
Does anyone know what would cause this. Haven't had it before and it might be that the dip stick is loose and needs replacing but I thought I would ask the question in case it's caused by something more sinister, like a build up of oil pressure. Car has been running perfectly and the oil level is correct.
Cheers for any comments,
Ian
Post #470272 27th Feb 2018 4:19pm
This can happen if the oil circulation "vortex" filter gets blocked up (well it did on my TD6) something similar on a TDV8 ? .
Post #470274 27th Feb 2018 4:29pm
ije44
Cheers Joe,
I'll look into it, not sure the TDV8 has one even.
Thanks for the pointer.
Ian
Post #470278 27th Feb 2018 6:07pm
wayneg
Has anyone else had a dipstick issue? Today I went out and 10 mins in I noticed a fair amount of smoke under acceleration. A little time after I get the bong of doom, engine system fault. Stopped, turned off and restarted and all good. Drove to the next layby for a quick inspection and top front of the engine driver's side covered in oil. As I changed both top turbo hoses a few days back I thought maybe another hose split. After checking everywhere and finding no obvious leak I discovered the dipstick was out of the tube 1cm and the source of the oil leak. There is every chance I either did not replace it correctly or lifted it up with a rag or something so fingers crossed. Not sure why a not sealed dipstick would cause an engine systems error.
The engine runs perfecty with no strange noises, under diagnostics there are no errors and all live data is good. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #626889 24th Mar 2022 9:58am
