Home > Technical (L322) > Suspension faults,,
stal108
United Kingdom 2003 Range Rover Vogue SE Td6 Mariana Black
Suspension faults,,
Hi All my first post
I have a 2003 l322, the suspension is down and it will not do anything, Today a friend who has one brought round his plug in gizmo,, Air suspension can error 8a, on the dash says Air suspension not active.
I bought it with the problem and thought it may be an easy fix,, but after spending hours today im at a loss,, I have checked fuses has the o/s front inner wheel arch cover off to look at valve block. Let remaining air out so I thought id disconnect battery and let it start from there,, But is just sits there and does nothing, I can not hear the pump work and even after deleting the fault its still on the dash,, Any ideas would be great.
Dave
Post #470052 25th Feb 2018 7:59pm
check and see if theres any feed going to the pump...if not then consider replacing it.. ... - .- -.
Post #470075 25th Feb 2018 9:08pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Don't forget when you clear faults on the air suspension you have to turn the steering wheel lock to lock (all the way left, then all the way right) before the lights will go out and the system reset. If you do this and the fault is still present then there is a hard fault somewhere. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #470148 26th Feb 2018 1:02pm
