Home > In Car Electronics (L322) > FBH? |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
Yes, you do. Located behind front left wheel arch liner, under the battery. |
24th Feb 2018 9:18pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 |
You should also have a remote control to switch it on and off and also to enable remote venting / cooling of the car in summer by blowing / venting outside air into the car 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
24th Feb 2018 10:10pm |
TDSIX Member Since: 18 Feb 2017 Location: Stirlingshire Posts: 210 |
Hmm.. I have no such remote.
25th Feb 2018 1:44am |
Yes, mine works over about 350 metres with a strong battery. They are easy to programme. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
25th Feb 2018 7:25am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
all diesel have FBH but not all have remote capability, mine doesn't. you can retrofit remote receiver and get remote controller. I just enabled timed start with IIDTool . it doesn't get that cold where I live.
25th Feb 2018 8:29am |
Remote FBH on Vogue and above was standard on the L322 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
25th Feb 2018 8:35am |
Mine has no receiver, I got car in Milan Italy-so different markets different options. TDSIX search this site for the receiver picture and check if you have one in your car.
25th Feb 2018 9:00am |
