Home > In Car Electronics (L322) > TMC operation with denso touch screen unit |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35439 |
can you tune to classic radio?
20th Feb 2018 8:42pm |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 |
Hi Stan yes all my radio stations work and the TMC used to search and store classic radio as I believe this is the station for TMC Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
20th Feb 2018 8:45pm |
if it doesn't store classic as the tmc station then maybe a battery reset will help...
20th Feb 2018 8:49pm |
I will try a reset via pulling the fuse direct to the TMC. Also any any ideas as to which fuse operates the cubby 12v and rear 12 socket near the aux ports as I'm getting no power from these so first port of call is to check fuses.
20th Feb 2018 8:52pm |
