![]() | Home > Technical (L322) > The dreaded judder...or is it? |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1559 ![]() ![]() |
A '97 super-charged? Ron B. VK2OTC
Knightmare Member Since: 22 Jun 2015 Location: Kent Posts: 84 ![]() ![]() ![]() |
Sorry, that'll be a 2007 SC! Less haste more speed |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Think I'd be sorting this miss fires first then go from there.
uteman Member Since: 23 May 2012 Location: Newport, Victoria Posts: 11 ![]() ![]() ![]() |
I have a L322 TD6
Thanks guys. Just been speaking to an independent gearbox specialist who knows the ZF transmission very well. He is betting it's the torque converter, something which I know has also been covered on the forum quite a bit. But I take your points Paul and uteman, just trying to minimise the frustration and expense.
I had a shudder when driving my car, thought it might be the torque converter, certainly felt like it. Before looking to change I found a front brake caliper sticking, changed both front calipers problem resolved. Might be worth a look. |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 545 ![]() ![]() ![]() |
Totally agree ref checking brake callipers, had the same on our '03 4.4 M62 two years back. Though it was gearbox, but turned out to be front left calliper sticking. I'd also sort that misfire as well.
Thanks gents. Brakes should be fine as these were just serviced and had new lines front to back...the issue was there prior to this so think brakes can be eliminated. I’ll tackle the misfire first then, although it’s not even perceptible unless the diagnostic laptop is attached. Thanks for the advice. Life is what happens while you�re making other plans. |
You may well be right, almost certainly are, but it costs nowt to check and just because brakes have been serviced (whatever that actually means, new discs, pads?) won't stop a calliper from starting to stick. Dead simple to check, take it for a run then when it's had a bit of a judder, pull in somewhere and see if one of the front wheels is hotter than the other. Drives:
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Don't know if this will help but I had a slight misfire on my 4.4 about 18 months ago, it was traced to the battery being weak. Once a new battery was fitted, never experienced it again. Current Fleet:-
Well, problem finally sorted |
