![]() | Home > Technical (L405) > Webasco Pre Heater starting up when vehicles turned off ! |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1403 ![]() ![]() ![]() |
It's not necessarily defective - it comes on automatically when the outside temperature is below 5 degrees C and can run on a bit after the engine is turned off. Sometimes on does get disconcerting smoke coming from the driver side wheel arch, as you say not nice/healthy in an enclosed space like a garage. Only Range Rovers since 1988 |
IansL405SDV8Autobiography Member Since: 18 Feb 2018 Location: Bedworth Posts: 5 ![]() ![]() ![]() |
Hi CS & thanks for your reply. Let’s hope your wrong or the dealers going to cop it for booking it in to be sorted out then if you feel it’s normal. Personally if your correct it just doesn’t make sense to me being an ex technician because why should it feel it needs to switch on for a minute when the engine/coolant/cab have already warmed up to operating temperature ! I personally don’t worry over fuel consumption but obviously it’s wasting fuel. I’ll feedback on here once the dealers checked it as I’ll either have an answer to a fault or a good story to tell about how I gave them what’s for lol 😂. What a car though, I’ve had a defender, four disco’s & now the FFRR Autobiography & I’ll never have another car unless LR screw the future RR’s up. Ian |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
Mine does this from time to time - never been able to find a pattern or recreate at will so knowing how useless LR dealerships are, never bothered to get them to investigate - I can probably predict their response. |
Hi Fokes, well it took my LR dealer a week to rectify the pre heater switching on by itself when I turned the engine off but I can confirm there’s a LR internal bulletin on this evidently & they did what ever they needed to. LR payed ! Happy day’s so my advice is speak to your dealer, Ian |
