![]() | Home > Technical (L322) > 2011 Parking Sensors |
johnb8538 Member Since: 15 Sep 2016 Location: Glasshoughton Posts: 71 ![]() ![]() ![]() |
Well after consulting the rave manual I found the parking module I was looking for is actually not in the drivers side wheel arch hidden behind the fuse box like older models but in fact it's in the passengers side wheel arch. Its also a lot easier to access.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2664 ![]() ![]() |
The plug for the rear sensors has wires in pins 3 and 4 whereas the plug for the front doesn't. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Can you get or borrow an IIDTool?
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Autoparts are often stamped year and week so suspect the date code is 2011, week 14.Some of the Range Rover parts have a full date code on them - look for a sticker inside one of the trim pieces like the rear panel hatches and so if those dates are roughly the same then you'll know if the module is original Current Fleet:-
Thank you for the replies folks. Sadly no I have no access to an IID tool which of course would pinpoint it straightaway I guess.
Just to box this off if it will help anyone.
Just to close this off.
