Home > Technical (L322) > Suspension Fault
Donimo
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Suspension Fault
OK, so i'm six months into ownership of a 2007 4.2 SC and I've got my first major headache.
'Suspension Fault' has started to appear on the display with associated compressor shut down and the light on the ride height indicator extinguishes. It will reset overnight, and not always occur at all on the next few journeys. It can occur at seemingly random times and I have not established a pattern yet. Today, after parking up for half an hour, the car had set itself in 'extended mode' I think it's called, and I was advised to lower the vehicle after clearing the obstacle.
I know from browsing the forum this is a common enough problem and there is a wealth of information - I am trying to decide on the least expensive diagnosis and fix. From my research it could be;
A worn compressor - simplest fix/DIY repair? a few pounds. Confused
A leak in the system requiring garage time - many pounds Sad
Large scale replacement of parts whilst a specialist finds the problem - bank loan Big Cry
I don't have a diagnosis tool to get the codes to give a fuller picture. Has the forum any advice on the best path to take?
Is the recommending of trustworthy independents allowed? I am in the South Manchester area. Current: 2007 RR 4.2 SC, now deceased, written off by an X5
Past: 1968 LR 2.25 (petrol) Series IIa
Post #469031 17th Feb 2018 5:30pm
drill a hole in the compressor filter, that might help.. ... - .- -.
Post #469036 17th Feb 2018 6:07pm
Silversurfer13
United Kingdom 2008 Range Rover Autobiography TDV8 Java Black
Ah Pal.... I feel for you
I had the same thing happen to me earlier this week and a very inconvenient time:
http://www.fullfatrr.com/forum/topic46406.html
Read the above and you'll see how ridiculously simple my fault was to fix.
I remember walking up to the car that morning and wondering why the rear wheels looked like they had vanished right up inside the arch.
I feel better now, albeit I missed out on the sale that had already been agreed!!!
Post #469045 17th Feb 2018 6:35pm
Sandyt
As Stan says first thing to do the compressor has a filter which inhibits the air being expelled from the compressor as it vents - the filter is full of silica or something similar and it breaks down and forms a dust which prevents the vented air being released so the vehicle goes into extended mode and you get a christmas tree of faults
Post #469048 17th Feb 2018 7:03pm
Sandyt
The filter silica dries the air on the way in and the expelled warm dry air dries the silica on the way out so that is what it is there for
Post #469049 17th Feb 2018 7:05pm
Donimo
Thanks, Gents. This was helpful, and will give me a focus for some investigation tomorrow. Current: 2007 RR 4.2 SC, now deceased, written off by an X5
Post #469072 17th Feb 2018 8:18pm
To avoid confusion:
stan is referring to the filter on the exhaust vent on the outside of the compressor
sandyt is referring to the air drier full of silica on the inside of the compressor
Do not drill a hole in the latter! - the silica can be dried once the compressor has been dismantled to access the drier. .
Post #469074 17th Feb 2018 8:21pm
Sandyt
Thanks Joe exactly so my fault Embarassed
Post #469075 17th Feb 2018 8:30pm
Donimo
So don't just drill everywhere!
I think I'll spend an evening watching dreadful YouTube 'instructional' videos.
My Saturday night >>> Your Saturday night? Laughing Current: 2007 RR 4.2 SC, now deceased, written off by an X5
Post #469079 17th Feb 2018 8:52pm
this is what i was referring to,
http://www.fullfatrr.com/forum/topic23038....or+exhaust ... - .- -.
Post #469097 17th Feb 2018 10:02pm
Donimo
That's even more information in that thread, Stan. Off the top of your head, is this a simple job (drilling the filter nut) that does not require the battery to be disconnected? Current: 2007 RR 4.2 SC, now deceased, written off by an X5
Post #469113 17th Feb 2018 10:59pm
Sandyt
To save you dismantle the silica filter once you have the brass silencer off cycle the suspension a couple of times and a heap of white dust will come out it is this that blocks the silencer and drilling stops the build up in the future
Post #469114 17th Feb 2018 11:12pm
Donimo
Update:
Drilling the silencer/filter has done the trick! This took a couple of attempts but I have now done it, and it seems to be fine.
Thanks to all who contributed - who on earth would think such a simple fix would cure such an annoying fault.
On a separate point, I have now learned quite how heavy the wheels are. 20' alloys with GGATs and I could barely lift the spare out of the well. Embarassed I wondered if owners generally get help (AA etc) with flats because this car is such heavy engineering? Current: 2007 RR 4.2 SC, now deceased, written off by an X5
Post #473125 19th Mar 2018 6:01pm
Aah... you don't have the easy lifting straps fitted Wink
Pleased to hear you sorted the AIR SUSP though Thumbs Up .
Post #473129 19th Mar 2018 6:37pm
nino_nino
Did mine as a preventive measure the other day.
I put a piece of lint free cloth over.
Donimo check my post on DIY spare tire lifting straps.
http://www.fullfatrr.com/forum/topic42071.html
Nino,
Post #473142 19th Mar 2018 8:51pm
