Home > Maintenance & Mods (L322) > Rear seat release mechanism fix
A few weeks ago I found that I couldn’t get the smaller part of the split rear seat down.
The release button at the top was very loose, wouldn’t unlock the mechanism and just flopped around.
This is the fix for it.
Firstly, you need to manually release the seat by sliding in a flat blade screw driver above the bracket that’s visible from the boot.
Once the seat is forward, remove the black plastic cover over the release mechanism. There are 3 clips holding it in place.
Looking into the mechanism, I saw that the steel rod that links the top button to the release lever had popped out
Having slipped this back through the hole in the release lever, it kept slipping out
Looking around, I found a circular locking clip, and once this was slid over the end of the steel rod, it was now secure
Replace the plastic cover and test
 Got - 2017 SDV8 Autobiography in Loire Blue
Post #468695 15th Feb 2018 10:52am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
rear seat release mechanism
Very good how to Thumbs Up
Post #468759 15th Feb 2018 5:27pm
Clive603
England 2004 Range Rover HSE Td6 Orkney Grey
Well fixed.
But those round, internal tabbed clips (spire nuts?) are generally one time use beasties. Assuming they are the right size and have been fitted properly the only reason for them working off is loss of spring / temper in the tabs. Tabs are supposed to be tight enough on the shaft that if the clip attempts to come off the tag "digs in" and gets tighter.
Generally careful inspection of an escaped one will show one tab bent up a touch more than the others. Uneven grip lets the thing slowly work its way off. Usual cause of a bent tab is smacking it on a bit tilted with respect to the shaft bending one tab as it goes on. If you are stuck and have to re use one with a bent tab careful work with a small socket or flat ended metal rod can bring things back good enough for now.
But make a note and replace soon.
You will be surprised how much tighter a brand new one is compared to re-used one. Getting things lined up square before pushing on can be a right battle working inside the car. I always get spares so I can bin any I might have damaged if it doesn't go nicely. Wasting a few pennies on clips beats the heck out of a do-over.
Clive
Post #468766 15th Feb 2018 6:40pm
Clabs
Alan
I had been meaning to address this problem on my car but wasn't quite sure how to go about tackling it. Your great write up made it quite literally a simple 10 minute fix.
Thanks very much for taking the time to post it up here.
Cheers
Mark
Post #469091 17th Feb 2018 8:43pm
Glad it worked for you Mark Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #469092 17th Feb 2018 8:44pm
nbunney
Anyone know what size the rod is?
Post #569284 9th Oct 2020 9:28am
cobolman
United Kingdom 2011 Range Rover Vogue SE TDV8 Fuji White
This is the article that got me to register
Thank you for this post. I had this exact same problem and this article provided the fix. 10 minute job.
On the down side, the captive washer got lost somewhere so I'll have to acquire another Very Happy
Post #574440 28th Nov 2020 5:44pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
Very helpful guide, thank you!
I noticed my single folding seat stopped working a few months ago, and finally had time to play with it last weekend. Exactly the same issue as described above, although if there was originally a locking washer on it, I couldn't find it anywhere in the vicinity! One of the clips on the cover broke off as soon as I touched it as well, so I wonder if someone has been here before, and just pushed the rod back into place as q quick fix, as it seems to last for a few usages before it pops out again.
I ordered a range of starlock washers on Ebay last weekend and tested them out today. I found what was marked as a 3mm starlock washer fitted nice and tight, and I don't think mine will be coming undone any time soon!
Post #580859 23rd Jan 2021 3:08pm
Mikek1300s
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Zermatt Silver
Had the same problem yesterday same fix have ordered some new star lock washers to back up the existing one that is getting a bit tired I suspect.
Cheers for the info.
Post #581731 30th Jan 2021 11:36am
Doonhamer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
Nice write-up and pics, thank you - will be looking to sort mine out this weekend. L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Suzuki Grand Vitara XL7 - sold
Mitsubishi Pajero 2.8 - part ex'd
Hyundai Santa Fe 2.0 td - sold
Mitsubishi Pajero 2.8 - sold
Post #656023 8th Feb 2023 11:37am
