Home > Technical (L322) > Rear Wiper Issues
tomh
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Rear Wiper Issues
Over the weekend I finally got around to attempting to sort the rear wiper after intermittent issues.
I removed the spoiler, rear wiper arm and motor assembly. I stripped the motor back, cleaned with WD40, replaced the plastic motor gear, re-greased and reassembled.
Reassembled back on the tailgate and reattached the wiper arm, tested and nothing...
So I removed the front cover from the motor assembly and reconnected, on engine start up the motor mechanics oved so I reassembled and reattached the wiper arm again and tested but no movement...
Inspected the spindle/pline and motor arm and the arm looks a little worn. Do I need a replacement arm or is it likely to be something else?
Any helps greatly appreciated
Post #468293 12th Feb 2018 4:26pm
bishbosh10
Does the spindle move when you ask it to form the steering column stalk? That will rule in / out worn splines. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #468586 14th Feb 2018 1:15pm
Stew 46
England 2007 Range Rover Vogue SE TDV8 Bonatti Grey
Had a new motor fitted on mine today , my Indy said water gets in from the wash jets and Censored the motor Big Cry around £100 plus fitting 07 VSE
Post #468613 14th Feb 2018 5:14pm
Beemergriff
Wow, that's a good price. Mine stopped working a couple of months ago, and this week I thought I ought to fix it at last, but new motors seem to be around £195.
Where did you get yours for £100 ??? Andrew
Defender 300tdi
RR Classic Off-road Trialer
BMW X3 E83
BMW 330 E46 convertible
Post #468907 16th Feb 2018 5:37pm
finchi
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
reply to tomh: Check you are getting 12v supply to motor?
Post #468940 16th Feb 2018 8:46pm
