Home > Maintenance & Mods (L322) > Nav unit failure (MK4)
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Drivnig to work today and the head unit rebooted four times then froze!!!!!!
After starting the car again (once at work) the Nav computer is not coming up.
Apart from the obvious (that its not well) has anyone had this? Nav unit has been working faultlessly untill very recently. "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #50439 16th Feb 2011 10:52am
first thing i would do is to take the disc out , inspect and re-insert..check for water ingress or damage...a battery dis-connection and re-connection might help if al is ok in the the first suggestion .. ... - .- -.
Post #50440 16th Feb 2011 11:07am
bozmandb9
Apparently it's a common fault, you can buy a fix on ebay for £150, or replace the laser unit yourself if you're brave enough! Range Rover-less at the moment - Pining!
Post #50442 16th Feb 2011 11:36am
MrP
If its the laser then i'm fine woth doing that myself. Dont think there is any water ingress - the car is always garaged and never had water issues before (but will check). "On first name terms with my local Dealer......now."
Post #50443 16th Feb 2011 11:40am
