Home > Maintenance & Mods (L322) > 2011 range rover 4.4 TDV8 Vacuum oil change. |
headless21 Member Since: 28 Jun 2016 Location: Yorkshire Posts: 23 |
Hi, I am just wondering where you vacuum the engine oil from (where to insert the tube from the vacuum pump), I have always used the sump plug before. Is there a specific tube to use or do you use the engine oil filling location? I can't seem to find any info on changing the engine oil via a vacuum pump on the 4.4 tdv8.
19th Jan 2018 9:55pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
here is the pic. to help you
19th Jan 2018 10:11pm |
That's brilliant, thanks for the quick response I really appreciate it. Current Range Rover Vogue SE 2011 4.4 TDV8
19th Jan 2018 10:15pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 801 |
Not seeing what you mean in the first piccie |
20th Jan 2018 3:09pm |
