Home > Maintenance & Mods (L322) > 4.4 TDV8 Coolant Change
carpcat
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Looking at changing the coolant tomorrow. Is this a standard procedure on this engine or is there anything special I need to be aware of? Also does anyone have a pic of the location of the air bleed valves and is there any order they need to be done in? Thanks Chris
Post #464705 15th Jan 2018 8:22pm
edward19
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
Hi
Did you work out how to change the coolant. Is there a drain plug on the radiator as I need to change mine. I've found a bleed screw on one hose but not looked further yet.
Thanks
Post #507845 7th Mar 2019 6:01pm
carpcat
Hi there. I did’nt change the coolant in the end. I topped up but only due to the repair of the oil cooler. I just opened the bleed screw to release any air. Apparently I believe it’s quite difficult to completely change all the coolant, did to the various coolant pathways that get shut off until they reach the required temperature.
Post #507856 7th Mar 2019 6:37pm
