Home > Technical (L322) > Oil Leak
Road Stone
Oil Leak
Hi Folks,
I have my first issue for ages. Just got back from leave the 2007 TDV8 having been parked up for 10 days. I noticed a tiny drop/oil deposit on the drive just in front of the drivers side front wheel.
Its light oil, clear in colour.
Any advice or opinions?
Many thanks, Jerry THIS WRECKAGE
Post #464609 15th Jan 2018 6:37am
Most likely steering, more worrying brake fluid. I'd get the wheel off and have a good look around .
Post #464629 15th Jan 2018 11:01am
p38arover
Australia
If it's conventional brake fluid, a taste test will tell you (assuming you've tasted brake fluid in the past - I have). Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #464632 15th Jan 2018 11:21am
Road Stone
Thanks, what is it meant to taste like?
I should of mentioned no fluid levels have dropped!
Cheers, Jerry THIS WRECKAGE
Post #464644 15th Jan 2018 1:59pm
