![]() | Home > Photos, Videos & Media > HS - Big car park fire in Liverpool. Land Rover started it. |
Whilst a fire extinguisher might be a good idea would you really want a fire damaged RangeRover in your ownership after it had been repaired. Given the amount of electronics that could be affected by a fire it's possible you could have a "repaired " car that causes you problems for years after the event. I think in such a circumstances I might just let the car burn and claim on the insurance. |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Should have put money on being asked that |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Thanks I'm ordering a co2 then!
Yeah, Halon was another name for BCF in Europe.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Not to state the obvious, but most of you will already have a battery isolator fitted to the car... the explosive battery coupling, I wonder if there is a way this could be triggered without the need to have a crash.... either a temp sensor that triggers it above a temp that you'd never get under any condition other than a fire... Or a switch in the car that can be triggered at will... obviously it would need a failsafe... ![]() ![]() ![]() My ffrr came with fire prevention features..... a blocked sun roof drain and leaky tailgate seal... I'm now beginning to think that this might have been a safety feature ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
Would prefer not to get a Chinese import.... And this one is Hfc-236fa - is this different to CO2 you mentioned earlier up Grofus? Seems 2kg is the smallest co2 I can find easily. But these are quite large. I was thinking a smaller 1kg that I could fit between the drivers seat and the centre console so I can reach it easily. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Hfc-236fa is the "new" Halon gas. Not quite as good as earlier stuff but CFC free and better than CO2.
uzp315 Member Since: 19 Nov 2017 Posts: 428 ![]() |
I really hope they identify the exact cause of the fire beyond "Range Rover" - i.e. FSR, FBH, careless owner with ciggy, vandalism.
I'd have thought that this sort of thing would be better as you don't have to be there to operate it!!
For sure Miggit, an automated system would be useful but AFFF relies on good application to be effective. It needs to be laid on not aimed directly at a fire but allowed to fall on. ( a bit like snow) In an engine bay it wouldn't be much better than water. Which, if the fire is because of a fuel leak, could make it worse.
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 228 ![]() ![]() ![]() |
Those types of systems work well although if you want something like that probably better off going here: www.firetrace.co.uk. |
Interestingly both systems..(the first I found) have the option of triggering a warning light... this could be used to trigger the explosive battery coupling! Extra safe |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
they saying 20 million in damage payouts |
