Home > Technical (L322) > From P38 to L322
mikomese
United Kingdom 2003 Range Rover Vogue Td6 Epsom Green
From P38 to L322
Hi guys newbie here been lurking a while but have now jumped from a P38 to a 2002 L322 Vogue 3.0 TD Thumbs Up
Generally very pleased until on friday my missus decided to adjust the passenger seat and operated the electric adjustment to make the seat back come up to a more upright position which it duly did, problem is that now it wont recline I can hear a clicking noise and a whiring noisewhen the switch is operated but the seat back doesnt move Confused If I operate the seat to bring it more upright it still works that way but wont go back. Confused Confused Has anyone come accross this before or any ideas what may be wrong.
Thank you in anticipation
Post #462776 31st Dec 2017 8:59am
mikomese
No one mine must be unique then. Oh well off to the dealers
Post #463230 4th Jan 2018 7:06am
welcome to the forum...
have you tried a forum search? ... - .- -.
Post #463231 4th Jan 2018 7:08am
rar110
I haven’t had this type of problem. I’ve had another minor problem. You could try unbolting the seat and carefully tilting it back to try to see the problem and possible solution. That’s what I did. It’s very simple to do, only 4 bolts. Good luck. ______________________________
Post #463329 4th Jan 2018 8:48pm
rar110
And welcome to the forum. I assume you are reasonably handy from being a P38 owner. Very Happy ______________________________
Post #463331 4th Jan 2018 8:53pm
mikomese
Thanks for the responses but still no further forward so I will make another appeal is there anyone local to me that could help out here? Here is the full situation I suffer with rheumatoid and osteoarthritis my left knee has recently been removed and my mobility is virtually nilly. The range rover is great for getting me about with a wheelchair but with the seat issue is virtually impossible. Also it's mot is due in less than a month away.
I live in Leeds so if anyone can recommend anyone who may be able to help me to sort the issue out or any independent range rover specialist. Obviously I would pay I am just trying to avoid having my pants removed by the steamers. All suggestions welcome. Thanks
Post #465069 19th Jan 2018 6:40am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Try checking the wiring loom under the seat. Had (one of many!) issues with ours a while back, the drivers seat was in the forward position for my wife, but then it would not go back at all for me. Turned out it was a broken wire in the loom under the seat, where it loops round and the constant forward / backwards movement had caused one of the wires to break.
Post #465105 19th Jan 2018 12:29pm
Baltic Blue
Site sponsors Green Oval are based in Leeds. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #465116 19th Jan 2018 1:20pm
