Home > Technical (L322) > Brake Judder
Stocky
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Fuji White
Brake Judder
Recently got back from a month down under. Very Happy Had left FFRR out in the cold but I must have inadvertently put the handbrake on before leaving it. Jumped in and it started first time. Shifted into drive and pressed the accelerator and it wouldn't budge Confused Brakes were locked on! Eventually after a bit of forward/reverse effort I got it moving. But there was quite a judder when applying the brakes, seemed to come from OSF. It gradually improved on the 200 mile trip, but still appears occasionally after a week now, all be it fairly faintly.
Question I'm assuming it was slight seizure of the brake pistons due to water/rusting. Am I correct? Am I doing any damage now?
Any suggestions gratefully received Bow down
NB Brembos on the fronts.
Post #47854 27th Jan 2011 5:38pm
the handbrake has shoes and drum is independent of the main front and rears which are pads and discs....i would agree that its probably a slight rust/moisture problem.. ... - .- -.
Post #47866 27th Jan 2011 6:17pm
Stocky
Of course Scarey. I forgot that little nugget. Thanks
Post #47874 27th Jan 2011 7:06pm
max abbi
I think it is a sticky caliper , best sort it now before it ruins your discs.
Post #48443 2nd Feb 2011 8:38am
