Home > Technical (L322) > Flip key
easylife103
England 2003 Range Rover Vogue Td6 Zambezi Silver
Flip key
Hi and a Merry Xmas to everybody.
I have just received a flip key replacement for the old lollipop style for my l322. After programming the key and using my old transponder in the new key and getting the blade cut, everything was working well, doors opened and closed correctly, engine starts etc. However, this morning as I drove to the shops, I noticed that the stereo was dropping out every few seconds, considering it was ok yesterday, I assumed that the new key was at fault. I tried the old key and all was fine with the stereo. Does anyone know how I can solve this?
Post #462053 24th Dec 2017 3:23pm
SteveRRL322
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
Strange, which flip key did you buy? Pic?
Post #462068 24th Dec 2017 5:27pm
easylife103
Hi Steve, I bought it off the bay of e
Here is the link
https://www.ebay.co.uk/itm/Range-Land-Rove...SwYVlaMrKU
Post #462076 24th Dec 2017 5:45pm
SteveRRL322
I’ve just bought the same one did you have to remove a blank transponder before putting in yours?
I will swap spare transponder over and try it and will let you know if it messes with anything.
Merry Xmas
Post #462101 24th Dec 2017 8:29pm
Paul thornton
Looks cool does that. If you can get it working that is!
Post #462109 24th Dec 2017 9:23pm
easylife103
Crisis averted, it turns out that I hadn’t placed the transponder close enough to the blade end of the flip key. The car was therefore only receiving an intermittent signal causing all the fuss. I have now put the transponder in the gap right next to the blade and all is now well Thumbs Up The new key is excellent, much better than the original.
Post #462163 25th Dec 2017 5:28pm
SteveRRL322
Hello Easy
How hard was it to get the blank transponder out of the new key?
Thanks
Post #462166 25th Dec 2017 6:01pm
easylife103
Hi Steve, the new flip key didn’t have a transponder in it. I used the one out of my original key
Post #462171 25th Dec 2017 6:55pm
SteveRRL322
Ok thanks mine came with a black one installed which I have finally got out but
It was a pig.
Thanks
Post #462174 25th Dec 2017 7:09pm
easylife103
No worries Steve merry Xmas mate Thumbs Up
Post #462185 25th Dec 2017 10:14pm
Nifty190
United Kingdom 2006 Range Rover Vogue SE Td6 Buckingham Blue
I got one of these and timpsons drilled a hole right through it when cutting it and said its not our blank so its your fault ..... trying to find just a new blade now
Post #462462 28th Dec 2017 3:23pm
SteveRRL322
The eBay guy I bought mine from posted one out for £5.50. Try where tou bought it from.
Buy the way the Timpson I used drilled through mine!
Post #462466 28th Dec 2017 3:34pm
Balloonengineer
Any idea who would cut a key in Kent?
I tried the Maidstone LR dealer and the parts person almost laughed off his chair. Rolling with laughter Haven't seen one of those keys in years, no we don't cut them, no I have no idea who would cut them for you. You will have to go to a specialist. So a dealer is not a specialist then........
Glen
Post #462601 29th Dec 2017 1:31pm
