Home > General > 2007 vogue at a good price?
Paulus1978
England 2008 Range Rover Vogue SE TDV8 Santorini Black
Looks like a reasonable example. Ignore the sellers hype, it's not "fully loaded". The missing "Logic 7" badges on the speaker grill has me doubting if it's the Harmen Kardon premium system. That said, the important stuff is on the Vogue spec anyway. Make sure EVERYTHING works. If it has a button, expect it to function. Pay particular attention to the turbos (no bad noises, no rattles or lack of pull) as they're £3,500 to sort. Make sure the gearbox works smoothly, and ask when the gearbox, transfer box and diff oil were last changed. If they look confused assume never and make that one of your first jobs if you buy it. Make sure the ride height raises and lowers from the switch in the center console. Air struts and pump are another expensive thing that can wrong. Check the DVD Nav operation if it has it. The roof aerial can become ingressed by water and stop receiving GPS signals leading to an inaccurate positional representation on the screen.
Edit: also check the steering column moves in all directions, they can fail too, and are unexpectedly eye-watering to fix.
All that said, if they've knocked a grand off, that's a fair price for whats on show here, assuming no faults are present.
Post #462148 25th Dec 2017 11:24am
Paul thornton
Seat looks fine to me, wouldn't say it's heavily worn at all.
'Massive spec' or 'fully loaded' is just car dealer talk that they use to describe everything.
As already said, just make sure everything works.
Next car I buy for that kind of money I'm definitely going to have an AA inspection done as they check things you wouldn't even think of.
Well worth the money and if the seller gets twitchy when you suggest it you know they've got something to hide.
Post #462156 25th Dec 2017 1:08pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Looks to me as though the drivers seat bolster is all the way through at 1 point. A dot which is yellow i.e. the colour of the seat foam.
Seems pretty well priced, especially with the grand off original price.
Just keep your eyes open and see through the dealer bullshit. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #462157 25th Dec 2017 1:25pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
i cant find it using that no ??? RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #462159 25th Dec 2017 3:47pm
TDSIX
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
As noted above, I reckon that is a spot of water with the interior light reflecting off it...
Post #462167 25th Dec 2017 5:17pm
Paul thornton
Did you buy it then?
Post #462358 27th Dec 2017 6:30pm
Mr.plow
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
I've recently purchased similar. Best to budget for something unexpected to happen. Two front struts within 6 weeks!
Post #463041 2nd Jan 2018 5:31pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
it is keenly priced when looking around the market at similar cars , id HPI it , its been detailed to death , waaaaay to shiney for a car of that year and mileage imo
Post #463077 2nd Jan 2018 8:23pm
