Home > Technical (L405) > Blind spot sensor blocked
AMTony
Had this message pop up today - has anyone any ideas?
Post #461728 21st Dec 2017 10:04pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Just clean the car, its probably caked in salt on sensor
Post #461735 21st Dec 2017 11:05pm
basil
2014 Range Rover Autobiography 5.0 SC V8 Mariana Black
This may be applicable to you?
Vehicles affected by service bulletin:
2015 Land Rover LR4
2015 Land Rover Range Rover Evoque
2015 Land Rover Range Rover Sport
The problem: The left or right blind spot monitor module may experience a water leak. Should this occur, the blind spot monitor may not work on the affected side.
See More Service Bulletins
Corrective action: Dealers will replace affected blind spot monitor modules.
Warranty info: This repair is being done free of charge under the new-vehicle limited warranty. This service bulletin expires June 30, 2017.
What owners should do: Call your local dealer with your vehicle's identification number to determine if it's involved in this service bulletin. You can also call Land Rover directly at 800-637-6837 or NHTSA at 888-327-4236. Reference TSB No. Q470.
Post #461736 21st Dec 2017 11:06pm
AMTony
Thanks for replies.
Car is really dirty so will clean.
Will also give LR a call and see if my car is affected. It is a mid 2016 so it could have some of the dodgy sensors?
Post #461760 22nd Dec 2017 5:55am
