![]() | Home > Maintenance & Mods (L322) > Re-Map???? |
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 174 ![]() ![]() ![]() |
Could you imagine!!!! Errrrrr actually we can’t we do it..... |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Try this from another source.
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
It won't be a bespoke map for £350, it will be a generic map for that sort of money.
The wheels I bought had fairly worn scorpion zeros 255/50/20s on I then changed to the 255/55/20 General Grabbers at3
Have you had anyone look at the car and see if any fault codes are stored etc...? You could be wasting your money with a remap if there is a different problem that a remap wont cure.
I’ve not had any dreaded bongs or warning lights, Good point tho, I’ll get it checked |
So, to be clear. The car came with standard tyres on and you changed them to 275/40's. Now you have 255/55's on.
When I bought it it had the 275/40/20s on and done 28mpg according to the OBC, I then bought a set of new to me alloys (originals needed refurb) with the ‘standard’ 255/50/20 scorpion zeros on which I then changed to 255/55/20 AT3s (they don’t make a 255/50/20 AT3)
I had to wait a few weeks for the AT3s so was on the 255/50s for a while which is when I noticed the differences, the 255/55s seem to make the hanging more noticeable |
Ah, OK got it. So did you feel it was "hanging" on the standard size tyres as well. At what speed do you notice the "hanging" and is it just top gear or other gears too. I can't help thinking a gearbox reset may solve it. There is a big jump in rolling circumferance for the gearbox to adapt to. The easiest way is with a diagnostic tool. I can't see how an engine map would solve it. It uses engine rpm, engine load, road speed etc to select a gear. An engine and gearbox re-map would work or just a gearbox re-map. You also have your own mind to recalibrate too as the speedo is now reading 20% slower than with your original set up.
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
Jumping in ... ... how do you reset the gearbox ECU? I have an IID tool - not used yet as only arrived yesterday - and have just switched to 22” wheels from 20”. What do I put here then? |
Small Update-
Paulus1978 Member Since: 09 Nov 2017 Location: Leicester Posts: 89 ![]() ![]() ![]() |
Check all the hoses which would be under pressure, If the split is a small one, the oil will only be coming out when you're on boost. When i had a turbo hose go on my Jaguar, it was the Turbo to Inter-cooler hose, and it split on the engine side, so i couldn't see the split, only feel it when i put my hand round the back. |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3788 ![]() ![]() |
They will as you have slightly over geared it - the 55 profile are larger in diameter = increase in gearing 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
