Home > Technical (L322) > 1st Post - Heater always Hot |
colinwebster Member Since: 19 Dec 2017 Location: Devon Posts: 43 |
Hi all, my first post after joining.
19th Dec 2017 8:49pm |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
Opposite problem to mine - have you read the bleed threads on these? |
19th Dec 2017 10:06pm |
Yes Ive studied them all, most of them relate to the heater being cool if there is an air lock though, mine is the other way.. |
19th Dec 2017 10:37pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
20th Dec 2017 7:39am |
Thanks it’s not the centre vent I’m having issues with it’s the heater in general. |
20th Dec 2017 8:06am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3234 |
Have you got the air con button pressed in? It's the one with the snowflake and has to be illuminated to have the air con working. Otherwise you just have the heater function.
20th Dec 2017 8:42am |
It could be the bowden cable that has come loose on the dial nino said - easy to pull the vent out to check, takes under 5 minutes to rule it out
20th Dec 2017 9:19am |
(bit of a wiggle to get it back in) |
20th Dec 2017 9:20am |
Before you fit the thermostat seriously consider this mod http://www.fullfatrr.com/forum/topic39362....thermostat |
20th Dec 2017 9:21am |
Sincerely - Thanks to all for your replies - in order to avoid wasting anyones time, Id like to clarify further.
20th Dec 2017 1:37pm |
The centre vent is not connected to your issue IMO as, from what you say, it appears to be functioning properly. Have you checked that the AC is activated as per my post above? John
20th Dec 2017 2:23pm |
Yes, The air con switch makes no difference.
20th Dec 2017 4:21pm |
How about seeing if an air con test and recharge works? John
20th Dec 2017 4:54pm |
Again, thanks for you input, I think even if the aircon didn't work, IE no gas, the heater output would still blow cooler that it does. we are at 5 degrees c here in the UK
20th Dec 2017 5:00pm |
