Home > Maintenance & Mods (L322) > Anyone fitted auxilliary rear lights?
Shaun_
Hi, All.
If anyone has fitted auxilliary light(s) to the rear of their L322, (either as a work light or to supplement the reversing lights when manouvering in the dark) please could you post a photo of the positioning?
I'm trying to decide the best fitment option.
Many thanks
Shaun 2012 TDV8 Westminster in the New Forest
Also: Land Rover Series 3 SWB, Mercedes 280SL, Classic Mini race replica, VW Golf SV
Previously: Audi A8, RR TDV8 Vogue, Audi Allroad, VW Golf GTI Edition 30, Audi A4 Avant, A8, A4 Sport, A6, VW Golf Mk5, Bora, Golf GTI Mk3, Jetta Mk3, Passat, Jetta Mk1, Golf Mk1
Post #460851 14th Dec 2017 7:33pm
Paulus1978
England 2008 Range Rover Vogue SE TDV8 Santorini Black
The best option i've seen spoken of reccently is to fit uprated LED CAM Error-free bulbs in the reversing lamps, which as a byproduct illuminates where you're reversing to.
Post #460869 14th Dec 2017 9:48pm
Depends what you want - permanent or temporary - and whether you have to electrics or not......
Post #460881 14th Dec 2017 10:54pm
Giantlandyman
I've seen LED bumper lights that fit in place of the reflectors on Ebay.......you might be limited to red though as they're intended as additional brake lights.
Post #460891 15th Dec 2017 12:23am
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
You can get those in red and white LEDs for stop, tail and reversing. But then you need rear reflectors to be legal
Like these
http://www.ebay.ie/itm/Land-Range-Rover-Fr...Sw8gVX83IR 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #460902 15th Dec 2017 1:21am
NobbyC
United Kingdom 2005 Range Rover Vogue 4.4 V8 Buckingham Blue
Hamlet fitted some under his rear bumper see
http://www.fullfatrr.com/forum/topic24889-270.html
Post #460938 15th Dec 2017 3:34pm
wayneg
I fitted a 6" led lightbar connected to reverse lights. I was worried it might get snagged when off road but so far no issues, its been underwater a few times too.
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #461102 17th Dec 2017 5:39am
milleR
United States 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
My RR backfires and actually ripped one off. I went to go buy the LED bumper lights off of eBay recently and they come in red reflector like you said and also smoked. I didn’t want the LED ability, so I got the smoked reflectors, put them in and didn’t hook them up. I will say for anyone buying them, the wires and glue are real bad quality.. like the glue connecting the wires to the lights needs some reinforcement for the long term. But i’ve Been happy with them for a month now!
Post #461104 17th Dec 2017 6:02am
tidy job Wayne Thumbs Up ... - .- -.
Post #461110 17th Dec 2017 9:45am
Vogue
It looks like that light bar could be mounted even higher - perhaps on the opposite side of the armature opposite side to where the tow electrics go 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #461114 17th Dec 2017 10:24am
My supplementary reverse lights.
Post #461145 17th Dec 2017 2:44pm
Billaboard
United Kingdom 2004 Range Rover Vogue Td6 Baltic Blue
Sorry to revive this old thread, but I was looking at fitting one or perhaps 2 similar lightbars in a similar position as supplementary reversing lights and occasional worklights.
Are these the normal ebay 18watt units and were they just wired across the original reversing lights without bringing up lighting alarms or any other problems?
If there were problems with that I was thinking of some interface to a towing socket. Anyone tried this?
This has become suddenly quite urgent here as we only have about 1" to spare when reversing out between the gateposts and the bulbs have gone in the nearest streetlights. Old 110 2.3 Petrol ???? - ????
Old 110 200tdi ???? - 2004
1996 Discovery 300tdi 2004 - 2015 met fiery end being welded
2004 JEEP Grand Cherokee 2015 - 2017
2004 L322 Td6 2017 -
Post #462274 27th Dec 2017 2:37am
wayneg
The one I fitted was one from ebay, about A$10 shipped, fully waterproof and plenty of light output. Its wired to the reverse lights with no issue. The reason I put mine in this position was there is already a hole there to fit the mounting bolt.
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #462275 27th Dec 2017 3:01am
Billaboard
Thanks, Wayneg. I've ordered a pair. If I don't fit the second one, it will come in handy as a plug-in work light. Old 110 2.3 Petrol ???? - ????
Post #462287 27th Dec 2017 10:58am
wayneg
I also fitted 2 at the front low down, see this thread http://www.fullfatrr.com/forum/topic42918....+light+bar
I have them wired up to operate remotely with one of these cheap relays. I can switch them on and off in or out of the car..https://www.ebay.com.au/itm/DC-12V-10A-Rel...SwX~dWpwQ3 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #462291 27th Dec 2017 11:39am
