Home > Technical (L322) > 4.4 tdV8 faults
Baltic Blue
4.4 tdV8 faults
Are these faults anything to worry about?
They remained when I cleared the Adaptive Dynamic Fault ?
And a question that will show I don’t know much about the iid, how do I change it from km to miles?
Cheers
Post #460530 12th Dec 2017 12:19pm
i get 'open circuits' Mike, i think its when ecu cant get info or power ..i normally clear these faults and they dont come back but if they do and everything is working ok then i dont worry..
as for the kph to mph [speedo?].. thats in the 'trip' part on the dash menu .. ... - .- -.
Post #460547 12th Dec 2017 2:20pm
Baltic Blue
Thanks Stan but I meant the km reading on the iid.
Can the iid display miles on Fault screen? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #460550 12th Dec 2017 2:28pm
ah, not sure about that one Mike...
email to GAP? ... - .- -.
Post #460553 12th Dec 2017 2:37pm
carpcat
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
In the IID Control App, click the cog at the bottom which opens the settings, then click unit conversions and you can change all the parameters in there. Chris
Post #460580 12th Dec 2017 4:01pm
Plim66
United Kingdom 2011 Range Rover Vogue TDV8 Epsom Green
Hi Mike
I've just bought a 4.4 like yours same model and year etc. Had it a month and then a warning triangle saying reduced performance followed by limp mode. Seems intermittent. I bought an IId tool and have the same P040D egr temp sensor a circuit high temp come up. Did you ever get to the bottom of that one as I'm wondering if this the source of my reduced performance warning.
Andy
TDV8 2011 Vogue
Defender TD5 CSW
200TDI Defender 90
S3 2.25 88 petrol
Post #468747 15th Feb 2018 4:28pm
Baltic Blue
Andy,
Sorry but the snow in January put me off sorting the fault codes, but I have done 1k miles since I repaired the adaptive dynamic suspension fault in December and it has run perfectly.
I read a post recently asking about the same Fault code.
As for your reduced performance alarm,; have you read my 4.4tdV8 Fault log post?
First check I would make would be to inspect the 4 short rubber hoses connecting the plenum chamber to the inlet manifolds.
The original hoses are very soft rubber and tend to split but the replacements are much tougher and easy to fit.
Plenty of members to offer help on here.
Cheers
Post #468752 15th Feb 2018 4:55pm
Plim66
Thanks Mike I will have a good look in those areas. Appreciate the advice.
Andy
Post #468753 15th Feb 2018 5:04pm
Baltic Blue
Andy,
Also several members have reported splits in the seams of the plastic plenum, which gives the same symptoms.
Dealers use a smoke test to check for splits and hairline crack leaks.
Does it trip into limp mode when you reach 2,500rpm. ?
If so it will be the CSOV valve sticking.
Post #468755 15th Feb 2018 5:13pm
OtleyDominic
I am having the restricted performance on occasion too.
Fault codes as attached here. I believed it was caused by the water in the fuel system as it only comes on after the engine is warmed up, turned off then on. If I then stop the car and restart it then goes away for a while too.
Pointers very welcomed!! Help !
Post #469210 18th Feb 2018 6:54pm
do you get 'water in fuel' come up on the tft dash, if so replace the fuel filter or try and drain the water from it.... ... - .- -.
Post #469213 18th Feb 2018 7:01pm
OtleyDominic
Hi Stan,
It never comes up on the dash about water in the fuel etc, only 'Restricted Performance'. It has had a new fuel filter and housing though to try and resolve it.
Post #469215 18th Feb 2018 7:04pm
