Home > Technical (L322) > Is the 3.6 suppose to run hot? |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
I'd say it was just your hot climate. As you say, you have not had a problem. Maybe look into that waterless coolant if it's an issue. Engines run cooler as it is better at removing heat because it doesn't vaporise. Also virtually no pressure builds up so less strain on components. Plenty of info on the web about it. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
20th Dec 2017 9:26am |
Paulus1978 Member Since: 09 Nov 2017 Location: Leicester Posts: 89 |
Even after a 130 mile drive down to London, my needle remains resolutely back in the center of the gauge once she's up to temperature. It stays there too even if I've just taken a short trip into town. It seems that's where it's mean to be on the gauge during normal operation |
20th Dec 2017 1:07pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35332 |
in our warmer months i could feel the heat of the engine as i passed by.. my needle stays vertical all the time.. ... - .- -.
20th Dec 2017 2:14pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
twin turbo isn't it ? will generate some serious heat Id expect |
20th Dec 2017 2:40pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Yep temp gauge rarely moves from the verticle position once warmed up. Other than on that beach run. ______________________________
20th Dec 2017 8:38pm |
Yesterday the temps were well under 30 degrees, so the top of the bonnet was cool. However the driver side passenger side guard was warm. Could this be the fuel cooler transferring heat?
21st Dec 2017 7:52pm |
Bluegreygreen Rangie Member Since: 10 Aug 2012 Location: Australia Posts: 53 |
These modern engines types (including the 3.6) are designed to run hotter than older engines... and as some one said with the turbos and coolers etc it will get very hot under the engine bay , I do notice allot of heat is generated myself
22nd Dec 2017 1:25pm |
