Home > Technical (L322) > FBH diesel consumption and starting. Worried about nothing?
Hitby
United Kingdom 2008 Range Rover Vogue TDV8 Buckingham Blue
Hi all,
I've been using my FBH a couple of times a day, before work and before coming home. Presumably this can be hard on the battery but I do a 25 mile commute each way so hopefully it'll be getting enough charge.
I thought it was slower to catch when I started it tonight hence the question. Do you think this will be enough mileage to recharge the battery sufficiently?
Also, does anyone have any idea how much diesel the heater uses?
'08 3.6 TDB8 if it makes any difference.
Thanks in advance for any help Smile
Post #458845 28th Nov 2017 6:29pm
anorakmark
United Kingdom 2004 Range Rover Vogue Td6 Epsom Green
The FBH does have a fail safe device fitted. I'm sure that if the battery has a low charge then the FBH will not fire up. Also if you have a low fuel level in the tank it will not fire up.
As for the consumption I'm not too sure, but hey to hell with the fuel, it's nice to hop into a nice warm cabin.
Although you are doing a 25 mile trip I'm guessing there still could be a drain on the battery, especially cold mornings with the heaters running & headlights. If your doing 25 miles on a free running motorway then i'm guessing it should boost the battery up, but maybe in stop and start traffic this may differ. Late 2004 FFRR Vogue 3.0 TD6 Tonga Green
Previous cars
Series 3 V8 conversion
1989 V8 classic Vogue
1992 V8 Classic Vogue
1998 P38 DSE
Post #459259 2nd Dec 2017 2:38am
Zeppfish
The FBH uses .7 litre of fuel per hour on full power (i.e. When it is bringing the temperature)
And then it uses .34 litre of fuel per hour on part load (when it maintains the temperature)
They will not work if the battery voltage drops below 10.5 volts!
Generally if there is fuel, and power they work, and their mode of operation depends on a lot of factors. Such as outside temperature, coolant temperature, battery voltage, faults logged on the system eta 2006 RR sport HSE
Swapped for 2012 4.4td v8 Westminster Santori black with Ivory leather
BEEN SMILING EVER SINCE
Post #459263 2nd Dec 2017 6:33am
