Home > Maintenance & Mods (L322) > Tips on replacing Alternator
Blair
The cold weather seems to have killed my alternator Big Cry
I've found a decent replacement, and was planning to do the job myself, as it looks to be a straight forward nut & bolt job. But before I take it on, anybody have any tips? Access looks a bit tight, and will I have to break out the IIDTool afterwards?!
Post #458348 23rd Nov 2017 6:18pm
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Mine went and my Indy from memory charged me for 4 hours as just time consuming they said. Many thanks
Paul
Post #458356 23rd Nov 2017 7:47pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Which engine do you have? I looked on the profile but couldn't see.
The M62 engine alternator is water cooled, though quite straight forward.
Remove the vicious fan and radiator - which can be done in about 30 mins if you have the right tool to get the fan off. Then it is 6 (I think) bolts around the alternator and one for the power connection. Make sure you check the condition of the rubber seal of the one going back on, which is normally attached to the alternator.
Whole job is less than 2 hrs even if done on a drive. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #458376 23rd Nov 2017 9:58pm
Pvw10
2008 tdv8 Many thanks
Paul
Post #458377 23rd Nov 2017 10:00pm
goopta
2008 Range Rover Vogue TDV8 Zermatt Silver
You need the hands the size of a girl. Did mine and took ages worst part was getting to the plug in the back of the altenator. Some take the turbo off to do it, I managed without doing that radiator fan etc had to come out. Managed to get it out thr front but was tight and an absolute bar steward.
Post #458386 24th Nov 2017 2:20am
I think at this time of year and the awkwardness factor, I’d be paying someone else to do it Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #458389 24th Nov 2017 7:05am
Blair
Mines a 4.2 SC, so no turbos. Access looks the hardest part!
Post #458418 24th Nov 2017 10:52am
fisha
The access will be tight, but essentially it should just be a bolt off/on job. I would never have thought of re-programming anything ... it puts out a voltage when its turning and thats about it. V8 or else ...
Post #458419 24th Nov 2017 11:10am
