Home > Technical (L322) > Heated Seats |
AJ Johnny Member Since: 30 Sep 2017 Location: Bedfordshire Posts: 77 |
I have a similar problem. The passenger and rears work but the drivers seat drops out after half a second or so. It worked ok until I got an original sub-harness to fix the hvac battery drain. The car is new to me but must gave had the drain for years because a battery isolator was fitted as they couldn’t trace the drain. Now the drain is cured but the driver heater drops out and at the same time the hvac drops out to but the restarts. If I unplug the harness the heater works ok.
25th Nov 2017 12:21am |
ianr63 Member Since: 26 Oct 2017 Location: Cheltenham Posts: 13 |
Thank you I will have another look, the vehicle is new to me also as of July this year, I have got used to our 53plateand all its quirks but this one is a whole new learning curve, I will let you know of any progress. |
25th Nov 2017 11:04am |
