Think it's this, which I have saved a print-out from somewhere, as my 2016 has the electric tow arm. Never a problem so far!
But do note you must NEVER fit a towball cover to it as there is not enough clearance when stowed.
I quote:-
" Issue:
A customer may report that the power/electrical socket for the EDT (electronic deplorable tow at) does not deploy when the bar is deployed.
Cause:
Under some conditions the tow power/electrical socket stays in the stowed position
(Yes, we bloody well know that 'cause that's what we've just complained about )
Action:
If the customer reports the power/electrical socket not deploying a service kit is now available, VPLGT0138, which replaces the existing part.
Post#403724 6th Sept 2016 7.33pm"
Hope that helps. Clearly a known problem. So may be under warranty.
I think this was an extract from a TOPIX bulletin. But no obvious TSB number etc. But it's obviously official.
Clive
