Home > Off Topic > How to trace a break in a cable? In a wall! |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3776 |
I don’t think even a cable locator would work, because it would detect the non broken wires. G reg 2.5VM Vogue Portofino red 1991- 1999
21st Nov 2017 8:20am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
If you have broken the live cable you might as well give up now and look to alternatives, you will never find the break without starting at one end and digging the cable out of the wall until you find the damage and even then you will need to replace the cable.
21st Nov 2017 9:02am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Thanks Mike. I do think energising the cable would allow for it to be detected. But I think I'd need some proper kit. Fault Tracers, proper ones are £400+. I could hire one but I've not used one before.
21st Nov 2017 9:14am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
replace the 75w bulbs with leds ones and it'll be even less of a problem Greg.. ... - .- -.
21st Nov 2017 9:25am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7950 |
No one would sign it off - so the only way around it would be to install a lamp socket - which could be signed off, then put a lighting plug on the end of your cable. Depends whether you have somewhere that could be done out of sight...... |
21st Nov 2017 9:46am |
No it’s not in accord with the IEE Regulations, strictly speaking an earth connection has to be made available to each fitting whether it is required or not. Using a blue coloured cable as a live cable is not that uncommon provided each end of the cable is clearly identified with coloured tape or even better shrink sleeving.
21st Nov 2017 10:21am |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
If you think the cable is damaged I would replace it. Running current through a partially damaged cable would be too risky for me, but then I live in a wooden house! |
21st Nov 2017 10:40am |
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 153 |
Would one of those voltage sticks work, ie the cables not to deep in the plaster.
21st Nov 2017 4:05pm |
Did you cap it with plastic or metal ??
21st Nov 2017 4:24pm |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
Exposed cables are all the rage right now...... https://www.pinterest.co.uk/explore/plug-i...t/?lp=true |
21st Nov 2017 4:34pm |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1235 |
Something in this , as I smelt then could see smoke coming from a bad connection... fortunately we were in - |
21st Nov 2017 9:04pm |
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 279 |
Or, if you don’t want to risk killing someone by electrocution or a fire, you could simply replace the cable! Given these potential consequences, isn’t a little disruption in pulling out the damaged cable (attaching it to a drawstring as you do so - to pull through a replacement cable) so bad? Better still, get an electrician to do the job for you, in order to comply with Part P. Sorry to go off on one, but I see the consequences of poor practice. |
21st Nov 2017 10:31pm |
Hi thanks for the comments.
21st Nov 2017 10:46pm |
