![]() | Home > Maintenance & Mods (L322) > Never ending saga of water in the boot finally sorted! |
anorakmark Member Since: 18 Jan 2014 Location: Chatham Kent Posts: 121 ![]() ![]() ![]() |
Your right Andy, yes it's common practice now mate. Hopefully if all stays dry then I will have 3 redundant ducks for sale |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Had same issue been ######g me off for a while and couldn’t get to bottom of it I had a leaking gps antena which was cause of water coming into to left hand audio equipment compartment and once I cured it I thought book leak would stop but NO DID IT ###k so this must be the reason I will give this a go cheers👍 Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Certainly give it a go. I tried everything trying to cure mine and was at my wits end |
Yeah seems like they are prone to this same leak as there are many people online reporting the same issue there’s also reports of water ingress from the rear quarter glass.
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
I'm not that familiar with this layout. Can you give me/us a reference point on a body diagram where these pictures point to? I have minimal rust in the side compartments which I should address. |
Yes it has been documented that the side quarters have been known to leak. Although I have to question this, are these windows taking the blame for water ingress somewhere else? I really thought at first that my side quarter was to blame but after running extensive water tests it turned out to be the upper tailgate hinges. Any FFRR owner that has the water issure may want to pay attention to this area. |
This picture would be, if you were sitting in the boot area and looking rewards towards the tailgate, it's the lower boot floor inside where the spare wheel sits. The panel with the round holes in is the bulkhead, it's between this panel and the outer panel that the water sits, there is a welded seem that the water travels through into the spare wheel well. If you look closely at the picture you will see the puddle of water making it's way through. Ignore all the wires as these are for my aftermarket tow bar so you may not have these on your FFRR. |
So this water seen in the pic is water pooling in the spare tire well? Does this water also make it to the side wells where the radio/sat navigation sit and the other side with the fuse box? |
Yes the water has travelled in from the bulkhead and actually travelled from the upper tailgate down the N/S rear pillar and into the boot area, it then comes through the seem and floods the compressor area. I was lucky as my sat nav & audio compartment was bone dry, I was constantly checking it daily and could not find any sign of water. There are many other FFRR owners who have had a flooded sub woofer and sat nav, so it looks like the water can take various routes. The most common issue seems to be the tailgate rubber seal, although I had replace mine but due to the hinge faces leaking the seal was pointless. I'm now on my second tailgate seal & hopefully the last. If you open your rear lower tailgate, lift up the wheel cover and look in the far left hand corner you will see a purpose made hole. stick your finger in this hole as far as you can as thos is the point of the water entry. I have sent another picture with the arrows showing the hole. to do the test run a hose and keep a close eye on this hole, of bung a rag in there and monitor it, my rag was coming out soaked.
Great right up mate I’m hoping this will sort my never ending issue of water ingress into the boot area. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Hopefully it will sort it, I know how stressful it can be trying to locate the source of water ingress. It's taken me 2 years to sort this issue out. I've just had the FFRR back from a service & MOT and thought I give her a qick hose down due to road salt GRRRR, totally drenched the rear end on the roof & tailgate & all is dry in boot, so fingers crossed this has definitely sorted this problem out. Please keep me updated, it's really a simple job, just a case of cleaning the mating faces, applying quality sealant and also doing the bolt holes & of course check the condition of that notorious boot seal. Late 2004 FFRR Vogue 3.0 TD6 Tonga Green
RG2024 Member Since: 08 Oct 2024 Location: Warwickshire Posts: 42 ![]() ![]() ![]() |
This post really helped me. I think I've had almost every type of water ingress in the one I recently bought. Sealed the tailgate mounting points, which immediately fixed the water coming into the boot on the nearside, but didn't fully stop water coming in the offside. Thought maybe I didn't do a good job sealing the tailgate mounting point, so went over it again. No difference.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3217 ![]() ![]() ![]() |
hinge welds were my inlet!
