Home > Technical (L322) > Gearbox - AGAIN!
TerryT-J
Wales 2005 Range Rover Vogue Td6 Java Black
Gearbox - AGAIN!
Well here I sit waiting for the RAC. Clunks and vibrations from underneath, trans. Failsafe prog on dash and come to a halt. No drive forwards or reverse. Switch off engine, restart, forward drive but no reverse. Not going to risk moving. This is a replacement box fitted 3 years ago. 30 000 miles. Not happy. Time for a total change of car I think.😡
Post #457646 17th Nov 2017 7:46pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Sounds like torque;i just revised mine. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #457649 17th Nov 2017 7:53pm
TerryT-J
Had to put transfer box in neutral to get it off breakdown truck. Seemed to be jammed n mater what position selector was in. Once off and fuse removed did not want to go backwards when reverse selected but would go forward! Would torque converter jam it up?
Post #457659 17th Nov 2017 8:41pm
holidaychicken
The problem with the TD6 GM transmission is the valve body is quite often overlooked during the refurb which is the root cause of the TC failure and so when everything is replaced if the valve body isn’t upgraded the reduced pressure on the TC causes premature failure from what I gather. Sometimes they fail after only 10 k miles.
When the TC fails on the GM TD6 box all the debris is sent into the transmission trashing that also.
Did you get any warning ?
Post #457678 18th Nov 2017 2:03am
TerryT-J
No, no warning at all!
Post #457692 18th Nov 2017 9:46am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I read posts like this and it once again puts me off buying a FF.........😩
Post #457741 18th Nov 2017 4:30pm
holidaychicken
Not sure if this is your cause but some information here.
I would imagine it is still economical to repair depending on where you go.
http://www.bimmerfest.com/forums/showthread.php?t=458451
I know nothing of these people but top of the google pile
http://www.rangerover-gearboxes.co.uk/land...gKD3PD_BwE
Post #457745 18th Nov 2017 4:46pm
Glynn
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Seems to me like these gearboxes are very poor, every one Ive owned (in either BMW or RR) have failed. Yet the Mercedes ones Ive never had a problem with
Post #457767 18th Nov 2017 7:06pm
holidaychicken
I get the impression the GM boxes are quite poor but the ZF boxes can at least be reasoned with
Post #457775 18th Nov 2017 8:57pm
TerryT-J
Well I got the FF back today, gearbox was re-built. Problem was an output shaft which is hollow that had what i can only describe as a spiral shear. It looked like a bog roll tube that had been opened up! I'm trying to get a photo.
Post #459950 7th Dec 2017 4:32pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Rrphil has highlighted this before - have a search and you will find a great photo of exactly this on one of his posts. Thumbs Up
Post #459961 7th Dec 2017 5:42pm
holidaychicken
Here is one of them, i do recall reading it now you say it.
http://www.fullfatrr.com/forum/topic14509.html?view=previous
Post #459975 7th Dec 2017 7:18pm
