Home > Technical (L322) > 3.6 TDV8 air filter and fuel filter question
themule
United Kingdom 2007 Range Rover Vogue TDV8 Zambezi Silver
Can anyone help, I want to change the air filter and fuel filter but can't find any info on the web about how to do it. I am assuming the air filter is in the box at the front right of the engine bay with 2 hoses going to it and 2 plugs?
I have seen the fuel filter wiki article for the 4.4 TDV8 but not sure if it's the same process and the pics are missing.
Thanks in advance. Andy
Post #456986 12th Nov 2017 1:09am
kbald
Air filter is in the box just undo the screws and replace redo the screws job done. Re the fuel filter its the same as the 4.4. Its by the air filter and you unscrew and remove and replace with the new one. It can be tight so some sort of strap type filter removal tool may be helpful. Getting it in and out is tight and fiddly but doable. You may wish to remove some things out of the way to make it easier or undo the holding bracket to give more room to work. Good luck Current 2007 TDV8 Vogue Buckingham Blue
Post #456998 12th Nov 2017 9:41am
themule
Cheers - I appreciate the help, the air filter was easy enough. The main issue was the screws has rusty heads.
I will do the fuel filter another day
Post #457066 12th Nov 2017 7:39pm
