![]() | Home > Maintenance & Mods (L322) > Charging Battery via towing electrics? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7975 ![]() ![]() ![]() |
https://www.disco3.co.uk/shop/tow-electric...c-p45.html
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Wouldn't have thought you will be able to charge via the towing electrics as there will be a relay in there somewhere which will only latch whilst the engine is running.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
I regularly keep my battery topped up using a CTEK connected to one of the towing socket adapters I bought from the forum shop.
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 504 ![]() ![]() ![]() |
Well, Ive ordered the adapter from the forum shop and extension lead and CTEK MXS10 CHARGER.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3874 ![]() ![]() ![]() |
I used to do that all the time, used a ctek and the lead that is - never then failed to start even on the coldest of days.
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
dunno about any relay but I charge my Fattie up thru the tow socket with a Ctek and the forum lead
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 226 ![]() ![]() ![]() |
On the 12s socket (white one) pin 4 is permantley live and pin 3 is ground so you can charge using one of the adapters on the site shop using a ctek.
Crispian22 Member Since: 25 May 2017 Location: Midlands Posts: 141 ![]() ![]() ![]() |
Just ordered one of those adapters,looks a handy bit of kit!
Yes although the adapter comes with a ctek style connector. One of the nice things about the creek is the fact that when you turn the mains off but leave it connected to the car it remembers the charge setting which not all of the smart chargers do |
https://rover.ebay.com/rover/0/0/0?mpre=ht...1322969937
UPDATE
How long do these usually take for delivery?
Hi Crispian22,
Emailed them this morning and just had a reply saying it's been dispatched 1st class.
