![]() | Home > In Car Electronics (L322) > Bluetooth upgrade. |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Disconnect it and see if there is any green on the pins. you may be lucky and be able to take it apart and clean it up, its very easy to take apart. I did it on mine when I was on holiday but mine was full of water so had no luck.
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
Cheers Alex, thanks for that.
Lee Marsh Member Since: 21 Nov 2016 Location: Herts Posts: 44 ![]() ![]() ![]() |
As yours is a jaguar set up (touch screen head unit) might find that Jaguar may do a later Bluetooth device.
Blair Member Since: 03 Apr 2017 Location: Suffolk Posts: 72 ![]() ![]() ![]() |
Also interested in the same question. Mine wasn't there, and had been bypassed when I bought it, so I'd like to know what breakers to look out for to get one! |
Thanks for the info Lee, I've actually managed to dry mine out and get it working again with no problems for the last week so fingers crossed it sorted, just have to keep and eye out for a leak somewhere.
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Very common issue the early Nokia Bluetooth module is crap disconnects and always needs re pairing to phone also signal quality and sound crap too. I had a leak very common which finished the module off anyway so I by passed it and a few months ago I bought a 2009 Range Rover sport Bluetooth module take a look on flea Bay many about ranging from £150 to £200 works great better sound clarity to. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
