![]() | Home > Technical (L322) > Irregular change from 2nd > 3rd |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1461 ![]() ![]() |
The obvious 1st step is to change the oil and filter ... at the mileage you are at, if the oil hasn't been changed yet, then it will be at the end of its life realistically. Worn out oil can lead to shifting problems. There are a ton of threads on this. The method is fairly simple and can be done at home.
seaneb Member Since: 25 Oct 2017 Location: Wrexham Posts: 10 ![]() ![]() |
Unnecessary quote removed
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
Oil and filter change and a dose of Dr Tranny can do no harm and possibly put the requirement for a new box off for a while.
Wurzel Member Since: 13 Sep 2017 Location: Gloucestershire Posts: 23 ![]() ![]() ![]() |
Thanks all. Per above it has just recently had an oil change and looking at the invoice, they replaced five litres which I don't think is all of it, but certainly more than is in just the sump? |
I had the transmission flushed through and then refilled a couple weeks ago. Has anyone had dealings with Planet Gears in Peterborough? £1250 fitted for refurb transmissions. Done a bit of research and they seem like the real deal. Can't find negative feedback anywhere and they seem very professional. |
Seaneb let us know how you get on with gearbox swap if you go for it, seems very good value. |
I will. I rang them today- talked to someone called Roy. Extremely knowledgeable guy. Went into detail about the process they go through. Best case scenario it will cost me £850 for a new TC and a few other bits but essentially the transmission rebuilt with most of the bits it had in it (because after testing, diagnosing and stripping it down that was all it needed) and worst case £1800 for a completely refurbed trans with everything replaced (inc valve body etc) except planet gears. All prices +VAT and including fitting. Bare in mind that after completing each stage the trans is refitted and test driven on the road before committing to the next stage.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
For any shift issues with the 6HP26 you should immediately suspect the solenoids.
RRPhil they say that they test everything including valve block and mechatronic. One thing that was pointed out to me which I have since checked is that the vehicle can quite often start off in 2nd gear. This resulted in me thinking that there was sometimes a delay in changing from 2nd to 3rd when in fact the problem is 3rd to 4th. |
Seaneb I've since noticed mine changes fine in manual mode with no slurring between 2nd and 3rd - does yours? Is also fine when cold. |
No when cold (first few minutes) it will often not change up even though the display says it has. It makes the occasional whining noise too if trying to get a move on up a decent gradient too. |
So my car has now been up to Roy at Planet Gears who echoed what my local LR specialist had already said, and that was that there was absolutely nothing wrong with it. Glad to have a second opinion in any case! |
Jon G Member Since: 02 Dec 2016 Location: Leicester Posts: 120 ![]() ![]() ![]() |
Mine went to Planet Gears in December last year as it was dropping to many Gears on kickdown, slipping badly and going into safe mode.
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 ![]() ![]() ![]() |
I'd be interested in any more thoughts on the fluid change issue. I hadn't previously come across the idea that changing out the dirty old fluid would do more harm than good, and to be honest seems counter-intuitive to me. Any one else got a view/any experience with this? |
