Home > Technical (L322) > Yellow suspension fault light |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2526 |
With the ignition switched on, check the plug to which the sensor attaches for 5V power between pin 1 (5V) and pin 5 (ground). If no power then check pin 1 to a good earth somewhere and check for continuity between pin 5 and a known good earth point.
26th Oct 2017 1:53am |
jaime Member Since: 25 Oct 2017 Location: Windsor Posts: 3 |
Yeah, sorry, only had the car 3 months so am really inexperienced with all the types/names for the different variations and wasn't until the early hours of this morning after much internet searching that I realised there was a similar forum to this for L320s.
26th Oct 2017 9:38am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35424 |
you'd be better of joining the RRS forum where you can ask specific questions about yours,
26th Oct 2017 10:53am |
Have joined that forum, thanks very much. Will still try the advice given above, but feel free to delete this thread if you want. Thanks very much |
26th Oct 2017 6:52pm |
