Home > General > How can a RR in PARK and Handbrake on roll down a hill?
GGDR
Some of you might have read the terrible story of a little toddler being hit by a runaway Range Rover in the last few days. I read today the initial report by the Coroner that the car was unlocked on a steep drive in PARK and had it's handbrake on.
I am trying to think how this is even possible. ok the handbrake might fail but the trans should lock in park. For both to fail? Chances of that are slim, no? Cheers, Greg
Post #447451 10th Aug 2017 10:14pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
My thoughts exactly, although with it being a 17 year old car it must be a P38, but if it was in park it should have held. Perhaps it was a weak or faulty gearbox linkage?
Post #447455 10th Aug 2017 11:26pm
and who turns their wheels to the kerb when they park on a hill these days? (I know it was in a driveway but still...) .
Post #447463 11th Aug 2017 7:30am
Andy-B
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
If the transfer box was in neutral then it would just rely on the handbrake alone.
Andy 4.4V8 Petrol Vogue 2002
Post #447501 11th Aug 2017 1:15pm
Sandyt
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
P38 could well have been manual
Post #447512 11th Aug 2017 4:18pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
The handbrake on the P38a acts on all 4 wheels as it's a drum attached to the transfer box, so considered very safe. The transfer box will only go into neutral if you take out a fuse and follow specific instructions regarding ignition key position etc, so really odd that it managed to roll away on its own... ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #447517 11th Aug 2017 4:44pm
sako243
The handbrake setup is I think like that on a Defender. Therefore it can act on four wheels, or three, or two, or one. By acting on the prop with open diffs it is relying on the wheels having traction. If they start rolling then all bets are pretty much off. Ed
Post #447532 11th Aug 2017 5:40pm
@Sandyt
News reports said the auto box was in PARK .
Post #447533 11th Aug 2017 5:40pm
UK Marine
Unless he was doing work on the transfer box and had it electronically in neutral then I can't see it as there is no centre diff lock on a P38a. It uses a viscous coupling to lock when needed and obviously only when under motion when the engine is running. ______________________________
Simon
Post #447535 11th Aug 2017 5:45pm
mzplcg
A P38 transmission has no locking diffs at all, only a viscous coupling in the transfer box. It has a transmission brake which acts on the rear prop shaft. So, if a rear driveshaft spline were to fail and allow the wheel to become disconnected from the drive then all wheels become free. This is the exact reason you never jack anything with a transmission brake unless the wheels are chocked, and it's why defenders, Disco 1 and 2 come with a chock as part of the jacking kit. It's also why transmission brakes are a really bad idea. One brake acting for all 4 wheels is a single point of failure with several scenarios for failure to happen.
As for the autobox being in Park, again, without locking diffs if one wheel can move then so can the other 3.
Post #447555 11th Aug 2017 8:16pm
RR2008HSE
We had a scare a few years ago while off-road in. One man's very young son got back in his Disco 3 (LR3 around here) at the top of a mountain. He managed the get the thing started before Dad got to him. Like the FFRR, it only needs to be put in gear and the parking brake will release automatically. Shocked Fortunately. All ended well.
Post #447669 12th Aug 2017 11:52pm
bishbosh10
I understand that the bits in the innards of an auto box associated with park are made of chocolate and you should never rely on park to hold the vehicle at any point. Always use the handbrake. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #448270 18th Aug 2017 1:08pm
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
mzplcg wrote:
A P38 transmission has no locking diffs at all, only a viscous coupling in the transfer box. It has a transmission brake which acts on the rear prop shaft. ............................................
In fact, for the application originally intended a transmission brake is a very good idea. The chances of a drive shaft spline breaking or an half shaft breaking whilst parked are slim to nil, the loading compared to being under power is extremely low. What you do gain is a handbrake well up out of the mud and water so it is almost always in a nice clean working condition. If you off road regularly you'll find drum brakes always full of mud, but the transmission brake is nearly always clean (ish), and it operates on all four wheels which, as you may know, is critical in some off road situations.
I trialed for years (full modified) and can't remember a transmission brake ever failing when parked.
Post #448286 18th Aug 2017 3:12pm
JarrahJack
Australia 2003 Range Rover HSE Td6 Zambezi Silver
Such a sad story.
Today I am going to adjust my handbrake so it works properly, We have our first child, a daughter, due in two months. 2003 TD6 HSE, Zambezi Silver, Navy Trim.
Post #448345 19th Aug 2017 1:55am
anorakmark
United Kingdom 2004 Range Rover Vogue Td6 Epsom Green
A very sad story indeed Crying or Very sad Crying or Very sad
My drive way to my garage is on a fairly steep incline and I have always had concerns about leaving it parked up on such a steep gradient, as we all know a hand brake can easily fail. I certainly wouldn't rely on the transmission being locked in park neither. As a precaution when parked on my drive I have the two back wheels chocked with 2 heavy duty wheel chocks for peace of mind. I have noticed when I have pulled up after a journey and applied the handbrake & selected park the FFRR still lurches forward or backwards a few inches depending which way parked. I can remember once I applied the handbrake & left the vehicle & when it came to driving off again I had difficulty removing the gear selector from park to reverse due to the car moving slightly after applying the handbrake & selecting park.
Post #454251 17th Oct 2017 2:57am
