Home > General > So, folks, will I manage with a diesel?
nwmgc
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Three year old 405s are looking rather attractively priced these days BUT just those running on diesel. Even my man-maths cannot run to a proper petrol engine, so find myself actually thinking about something powered by a thing you find in lorries and submarine engines. But I am so tempted...
I live in London so lots of short trips - plenty of time in traffic, of course - with the less frequent ventures out of town.
What think?
Post #453590 10th Oct 2017 1:42pm
GGDR
I'm in the big smoke myself - with a 4.4TDV8 - I love it but the DPF is clogging up a LOT. Cheers, Greg
Post #453591 10th Oct 2017 2:04pm
362bkr
Test drive one and the answer will be obvious to you .
Post #453597 10th Oct 2017 2:54pm
emilio
Malta 2012 Range Rover Westminster TDV8 Orkney Grey
dpf will clog up unless you give it a good run once a month. if you cant manage that id stay away from diesel. im a petrol head, love petrol but i found the tdv8 adequate in town and on motorways, obviously its a trade off you dont get the noise and its pointless revving it out but the torque makes up for it in a way.
Post #453619 10th Oct 2017 6:35pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
I’m a big fan of big diesels, but the combination of a lightly stressed diesel, fitted with a DPF, being run almost exclusively in city traffic is a recipe for trouble. Sorry Sad
I wonder if there’s a difference in the price of petrol 405’s if they are being sold well away for London?
Post #453622 10th Oct 2017 6:48pm
BOBSKI
Scotland 2011 Range Rover Vogue 4.4 V8 Santorini Black
the dpf just needs a good blast on the motorway once a week should keep it tip top
Post #453626 10th Oct 2017 7:53pm
^ a steady 50mph for about 15-20 minutes for the dpf to re-generate .. Thumbs Up ... - .- -.
Post #453629 10th Oct 2017 8:07pm
Red Merle
Reading the OP’s post would suggest that it’s mostly stop start town traffic.
Post #453644 10th Oct 2017 9:00pm
Crispian22
Tbh,for city driving,I wouldn't even entertain the idea of a modern diesel.
What you may save in fuel will be sure to be spent on repairs,many times over.
Post #453655 10th Oct 2017 9:53pm
Giantlandyman
When people think of London, they usually think of rush hour, Central London and 30mph roads but as we know, there are several parts with dual carriageways where a 15-20 minute run at 50mph is easily accomplished.
Only you will know if you are able to do this regularly.
Post #453739 11th Oct 2017 3:54pm
nwmgc
Thanks gang. All probably explains why they're cheaper (ahem, if that's the right word).
That said, I can fairly easily do a 50 mph run if that is indeed a possible solution.. can you tell I'm trying to justify Very Happy
Post #453740 11th Oct 2017 4:13pm
GGDR
If that's close to you then go for it.
I'm 30-50mins (50 if traffic) from a 50mph stretch so it's quite a hassle when the yellow DPF light goes off.
When you get a yellow you need to do it straight away otherwise it goes red then it goes into restricted mode and you need to go to a dealer/mechanic to clear it.
The engine is sublime, effortless and sooo much torque.
Very economical too. Averages around 18mpg city / 35mpg motorway.
Which is unbelievable for a 2.5 tonne tank.
Greg Cheers, Greg
Post #453743 11th Oct 2017 4:43pm
Red Merle
I’m amazed that 15-20 minutes at 50mph would make any impression!
Even at 70mph, it’s doing less than 1,350 rpm and I’m not sure what good even that’s doing Rolling Eyes
Post #453745 11th Oct 2017 5:09pm
GGDR
I did my last one in 9mins at 50mph.
It chucks extra fuel in to get the DPF temperature right up
but it needs to air flow at 50mph to keep it from catching fire.
. Cheers, Greg
Post #453747 11th Oct 2017 5:13pm
