Home > Technical (L322) > 2012 Westminster Parking PDC ECU
TonyB
I have a 2012 reg RR Westminster and the parking sensors has a system fault (switch indicator flashing). I'm trying to locate the PDC ECU, which on earlier models is behind the wiring panel above the rear load space fuse box. On my model that's where the air suspension unit is located. Can you point me in the right direction please.
Would disconnecting and re-fitting the ECU re-set the system?
Post #453451 9th Oct 2017 2:53pm
Baltic Blue
Please keep this post updated with your findings for my 2010/12 Fault log.
Cheers. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #453453 9th Oct 2017 3:06pm
GGDR
Worth a try (disconnect / reconnect).
How about a battery reset too?
Greg Cheers, Greg
Post #453470 9th Oct 2017 3:32pm
TonyB
Thanks to you both! No luck after unplugging ECU and disconnecting battery.
I don't want an expensive trip to the dealer however, if I buy a replacement used ECU and that doesn't work.......
Post #453484 9th Oct 2017 4:01pm
Baltic Blue
If you PM me your email address, I will send you more info from WM.
B.B. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #453489 9th Oct 2017 4:23pm
