Home > Maintenance & Mods (L405) > Can you get replacement glass for headlights?
idrivemyhusbandscar
United Kingdom 2014 Range Rover Vogue SDV8 Corris Grey
Hello! I hope this is is OK to post on here?! I'm looking for a bit of help please. Today I managed to smash the glass in the front driver's side headlight (RR Vogue 2014) no other damage just the glass! Does anyone know if it is possible to buy replacement glass for this as I think it's going to be a costly job! I've just told the husband (it's a happy household here this evening!!) so I'm hoping that someone might be able to offer a cheaper alternative to a garage repair - or is this something that should only be done by a garage. Thank you in advance.
Post #452881 3rd Oct 2017 7:53pm
AndyS
You may well find used replacement headlights on ebay from a breakers. Will probably be a lot cheaper than a main dealer new unit and certainly worth investigating but you need to know if it's the adaptable version or not.
Post #452882 3rd Oct 2017 8:06pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Welcome!
It might be easier to get a second hand unit:
http://www.ebay.co.uk/itm/RANGE-ROVER-L405...SwnNFZuQx3
regards
John
Post #452883 3rd Oct 2017 8:06pm
the glass isn't replaceable..i would source from ebay as suggested above then find a friendly garage to fit it.. ... - .- -.
Post #452884 3rd Oct 2017 8:26pm
idrivemyhusbandscar
Thank you for your help - much appreciated
Post #452895 3rd Oct 2017 9:08pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
does your husband know then ?? Wink
Post #452906 3rd Oct 2017 10:00pm
idrivemyhusbandscar
Yes - he does Embarassed It's just so odd as I just didn't feel anything bang, it's almost like someone has hit the glass with a bat or something as there is no damage at all to anything else - just the glass that is smashed. Most strange Sad Rolling Eyes
Post #452982 4th Oct 2017 7:50pm
bembo449
sounds very odd indeed , must have been summat stuck out that you didn't spot in time ??
Post #452987 4th Oct 2017 8:38pm
