Home > Maintenance & Mods (L322) > L322 front end knocking
Jdd212
United Kingdom 2002 Range Rover SE Td6 Epsom Green
Hi guys recently changed both front bottom arms along with drop links 4months ago and now suddenly got a clunking noise coming from passenger side.checked most things that it could be but can't seem to pinpoint where it's coming from?as anyone else had this problem?also do the sway bar bushes supposter have slight movement ?Thanks jak
Post #452650 1st Oct 2017 5:59pm
are these the bits that need to be tightened when the FF is on the ground ? ... - .- -.
Post #452652 1st Oct 2017 6:11pm
Jdd212
Not sure what u mean by that Stan lol .i changed everything apart from the sway bar rubbers and now got the clunking/knocking from the passenger side
Post #452653 1st Oct 2017 6:16pm
Jdd212
Think I get which bit your talking about.but I avnt changed those rubbers as yet
Post #452654 1st Oct 2017 6:17pm
gizze
Did you use OEM parts, or at least Lemforder or high quality?
Might just be they have gone already, had that happen before when using the ECP 'cheaper' part. Porsche 911 (996)
2015 BMW 5 Series Touring
Not got a LR of any kind at the mo, and got itchy feet.
Post #452658 1st Oct 2017 6:31pm
Jdd212
Hi m8 ye i got them off ebay from jgs4x4 😐not sure the quAlity but I'm pretty sure that could be my problem aswell as I've got quite a bit of movement on the front /rear arm .to be honest I'm hoping it is them as I've spent so much money on it 😲
Post #452659 1st Oct 2017 6:36pm
Jdd212
Apparently OEM parts
Might try the sway bar rubbers
Post #452660 1st Oct 2017 6:44pm
fisha
Did you replace the ball joints that fit into the hubs at the same time as you changed the arms ? Those are large and prone to wear and cause vertical play in the joint. You cant easily test this when the car is grounded as the car weight keeps the joint compressed together. I could only see / test for play when the joint was fully split apart and it was under no loading.
You should be able to hear from which side the knocking is coming as a starter. V8 or else ...
Post #452682 2nd Oct 2017 7:39am
Jdd212
Yes m8 changed the lot and suddenly its come back .I'm almost certain now it's the sway bar d bushes and drop links
Post #452724 2nd Oct 2017 4:34pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
I too have an annoying knock after renewing the front bushes and drop links , mine just seems to knock for the hell of it ! theres a cobbled road on my way to work and the car doesn't knock at all going over that Mad
Post #452774 2nd Oct 2017 8:42pm
