Home > Technical (L322) > Lost drive
alistairh
Lost drive
Was sat at a set of lights and put car into sport and as I'm pulling away cars lost all drive in any gearbor mode.. tried selecting low range which it did then it will only come out of low when I switch off car...shall try and upload video
Post #451119 16th Sep 2017 4:14pm
alistairh
Post #451120 16th Sep 2017 4:23pm
alistairh
Post #451132 16th Sep 2017 8:33pm
RRPhil
If your car missed the Q041 Service Action then the front propshaft spline may have worn away through misalignment
Otherwise, it could be that one of the front inner driveshaft joints has popped out
Phil
Post #451143 16th Sep 2017 10:26pm
alistairh
Hi Phil. The joints been suspect for a while. Selecting reverse or drive would give me a slight thud. Pete mentioned a joint ages ago when I posted about it..hopefully it's that that's gave way. Thanks for the input.
Post #451145 16th Sep 2017 10:41pm
