Home > Off Topic > Any gas fitters? |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
I'm fitting a new gas hob and need advice re the fittings on the supply pipe if anyone can help? |
12th Sep 2017 3:55pm |
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 |
Advice on fitting gas hob: pay a gas fitter £80 to do it it code and test fully. |
13th Sep 2017 7:14am |
Yeah if I was soldering pipes and the like I probably would, but this is simply a fitting I’m asking about. |
13th Sep 2017 7:23am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1345 |
most likely this
13th Sep 2017 8:09am |
The current set up is a copper pipe with an elbow and a threaded nut soldered into that. screwed into that nut is a 90 degree male/male elbow which has some kind of cement sealing it. When I unscrewed it, there is a rubber seal inside so it’s not a taper fit. I have another 90 fitting that needs to go in (male/female seen in pic) but I was wondering what the cement is and how I can position the fitting to line up with the hob as it screws in facing the opposite way by the time it’s tight.
13th Sep 2017 8:21am |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
If you seal it yourself you can't test it so get a plumber. Agueroooooooooo. 93-20
13th Sep 2017 8:31am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Last time I did a similar job I used this, never had a problem. Test with soap solution on the joint afterwards or if you want to do it properly buy a manometer and check the whole installation
13th Sep 2017 8:42am |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
With all due respect if you can't work out how to make that straight forward connection you shouldn't be touching it. |
13th Sep 2017 4:51pm |
I can work it out. It’s simple enough. The fitting I have will go straight into the the copper pipe fitting. My query was that if I tighten it, it’s facing the wrong way. I don’t want to turn it another half turn to line up as I may strip the thread. If I back it off half a turn it’ll be loose. |
13th Sep 2017 4:55pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1420 |
It's illegal in the UK to do any work on fixed gas pipework so you'll need to get a gas safe registered engineer to do the connection for you. 2021 D350 Fifty Edition - Carpathian Grey
13th Sep 2017 5:39pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
PTFE tape comes in two types. White pack for water and yellow pack for gas. It's still white but it's a lot thicker. Simply called gas tape. Winding the right amount (trial and error) allows you to rotate the fitting so it's tight AND also ends up in the right position.
13th Sep 2017 9:28pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8524 |
If you don't get a gas safe engineer to sign it off then you are breaking the law.
23rd Sep 2017 6:40pm |
