Home > Technical (L405) > Rear Windscreen Wiper Service Mode
DangerMouseUK
United Kingdom 2017 Range Rover Autobiography SDV8 Farallon Black
Hi Guys,
Might be a bit of a dumb question, searched around a bit and can't find a definitive answer.
Has anyone got any idea how you get the rear windscreen wiper to go into some sort of service mode so I can clean it and possibly at one point in the near future change the blade?
I've seen some suggestions of opening the boot to stop it but I don't see how that would work if you're trying to wash the rear windscreen and wipe with water, etc.
Thanks !
Post #450664 12th Sep 2017 12:31am
DangerMouseUK
Quote:
To get the rear wiper to stay in the middle of the window without haveng to open the boot at the exact time this works on my MY15.5
1- turn the ignition on
2- turn ignition off. as its going off hold the right stalk down in the single wipe position
3- while still holding the stalk down turn the ignition back on front and rear wipers will move to the "service" position
leave the key in the car while you change the blades then turn the ignition off to reset them.
I'd watch out for the battery time-out though. if the ignition goes off they will probably return to their normal positions and if you've left them off the window then they are going to hit your bonnet.
personally I'd use winter park for the fronts as i can turn the ignition off and there's no danger of them moving and this if i ever need to do the rear although it would be nice to be able to clean up there once in a while.
Found that on the RRSport forum so will give it a try and see if it works tomorrow !
Post #450665 12th Sep 2017 2:00am
DangerMouseUK
Didnt get to try this today, anyone here tried this combo ?
Post #450775 13th Sep 2017 12:19am
I just open the boot - you have to time it, but as soon as you start to open it, the wiper stops, then stop the boot part way up and change the wiper.
Post #450779 13th Sep 2017 6:08am
DangerMouseUK
Yeah I wanted to wash the wipers as well and I didn't want to start throwing water about with the tailgate open.
Will try this at one point tomorrow !
Post #450874 13th Sep 2017 9:07pm
If you just want to wash it , then on intermittent, it stays stationary and exposed for long enough......
Post #450878 13th Sep 2017 9:48pm
Closerthanmost
1. Start the rear wiper
2. Open the upper tailgate - wiper will stop
3. Turn ignition off
4. Lower the tailgate
5. clean/change wiper
Or am I missing something ?
Post #450898 14th Sep 2017 9:56am
DangerMouseUK
Will give that a try too see if it works !
Sometimes when the ignition is off the fronts tuck themselves away but will see if the rear does it !
Post #450899 14th Sep 2017 9:58am
