Home > General > tmc [traffic management channel]
does it work for you?
i generally find the info inaccurate with 'slow traffic ahead' messages not collating with actual road conditions... ... - .- -.
Post #450151 7th Sep 2017 6:59am
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
For me it only seems to be useful for really major issues that last a long time. Info seems to be at least an hour out of date. Locations are approximate at best. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #450159 7th Sep 2017 7:29am
Gumby
England 2010 Range Rover Vogue TDV8 Zermatt Silver
I think it's always been relatively tardy (I remember it being the same on my old Discovery 3). Phone apps tend to be much more of an accurate reflection of real-time traffic, I guess thanks to the location data they can gather. If only they could use past data for to predict traffic behaviour though...!
Post #451405 19th Sep 2017 12:50pm
i've just done 1600 miles from swindon to germany and back and had it switched off...didnt miss it at all.. ... - .- -.
Post #451409 19th Sep 2017 1:14pm
Gumby
Good effort. If it's off then you certainly avoid the inevitable "do you want to reroute" box which always seems to reroute you into traffic...!
Post #451411 19th Sep 2017 1:18pm
j_rov
I find it totally inaccurate. Rerouting off motorways up the slip road and back on again, adding tens or hundreds of extra miles to reroute round traffic which doesnt exist.
I use Waze on my iphone now, which is a shame as it's a decent sized screen going to waste... __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #451413 19th Sep 2017 2:26pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
I find it to be rubbish. I get a warning and it tries to re-route me when I am already stuck in traffic.
The traffic warning in my Skoda is really good and is way ahead and re-routes me before I see any traffic.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #451414 19th Sep 2017 2:34pm
i'm glad i'm not the only one that finds it pants... ... - .- -.
Post #451415 19th Sep 2017 2:41pm
Sandyt
I switched it off a long time ago as it used to annoy me so much because it was so inaccurate - I used to get more angry at it than I did with the traffic Rolling Eyes Rolling Eyes
Post #451423 19th Sep 2017 5:07pm
anorakmark
United Kingdom 2004 Range Rover Vogue Td6 Epsom Green
Hi all.
Just some info for you regarding the TMC system on the FFRR.
I work as a service controller for London Buses in central London and as you all state the TMC is certainly misleading & here is why. As far as I'm aware the TMC system works in conjunction with certain radio stations like Classic FM which broadcast traffic information via the TMC network. What I can tell you as a London Bus Controller is that the traffic info which is used by many radio stations is so far out of date it's unreal. due to nature of my job I am in close connection with Centrecomm London and all the local authorities with regards to traffic situations & road closures in real time. The traffic information used by the radio stations and sent via TMC can be up to 60 minutes out of date and totally incorrect. I have heard many of time broadcasts on LBC London of roads that have been closed due to an RTC or police incident that have actually been reopened some 60 minutes prior to the broadcast, very miss leading. Fortunately I have access to real time traffic updates and real time cameras so I can see what roads are closed & which are open & traffic issues. As previously stated probably the best traffic app to use is Waze as most of the traffic reports are reported real time by the Waze community. The satnav system on the FFRR is great considering it was developed many moons ago, but yes the TMC is a let down but saying that if the correct real time info was broadcast to the TMC system then it would be a great aid.
Post #454250 17th Oct 2017 2:38am
i'm sure the motorway warning signs are connected to the tmc as they are always wrong.. ... - .- -.
Post #454254 17th Oct 2017 5:59am
I agree that this needs to be turned off, but so far I've been unsuccessful. In the TMC bit of the menu I've told it not to report on anything - but "there is slow traffic" is still a regular interruption. Wheres the off button please? Mike - MPx
Post #455314 25th Oct 2017 10:20pm
anorakmark
Hi MPX
I'm sure if you go into the TMC settings on your sat nav screen there is an option in there. I think it's in the same menu as you would use to set the broadcasting TMC channel.
Post #455423 27th Oct 2017 12:11am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
I work in this sector. TMC data is very old technology now. The vehicle’s radio has a second tuner where it (not you) listens to an enabled TMC broadcast. In the UK, TMC is broadcast on the back of Classic FM.
There are a couple of things to bear in mind for optimum routing:-
1) up to date maps. Roads are changing and being added all the time. Not only this, the average road speeds are constantly changing too, a good system should take account that e.g. the A422 between coordinate x and y typically moves at z kmh at 08:06 on a Monday morning. Buying the latest DVD will give “newer” maps but they are still going to be laughably out of date at the point of you installing it.
2) live traffic. Driving without traffic is a really bad idea. You can have the best most up to date maps in the world but to be directed to the back of a huge traffic queue is frustrating at best. The M1 was shut the other day for 10+ hours and this seems to happen more and more with much more detailed analysis going on after a crash. Not funny.
Connected technology is moving very fast and most OEM systems are seriously dated before the vehicle is new let alone been through the used channels. The Whole Tesla business model is based on over the air (ota) updates where the entire vehicle characteristics, maps, diagnostics etc. are updated as you sleep. Tesla drivers’ have woken up to improved range, throttle responses, handling......
TMC is decades old now, it’s still live and free but things really have moved on, think of it as a very very narrow pipe.
I know we all hate dashboard clutter but I’m afraid that external devices / apps are the only way to go if you want to get to where you are going. I wouldn’t dream of driving anywhere without live, crowd sourced traffic as a bare minimum. Thumbs Up 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #455433 27th Oct 2017 8:59am
Stocky
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Fuji White
I don’t even bother with ffrr satnav, use waze all the time, most up to date every time. Thumbs Up
Post #455437 27th Oct 2017 10:02am
