Home > Maintenance & Mods (L322) > Flappy Paddles
j_rov
Flappy Paddles
Hi
Is it possible to fit the gear change paddles to all models? Just seen a set for sale and thought crossed my mind.
Mines a 2010MY 6sp Auto
TIA
Jon __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #449523 30th Aug 2017 1:54pm
millerj90
Majority of the problem is there are insufficient connections in the rotary coupler to support the operation of the paddles. I have read one person managed it with a "trailing lead".
The following article may help: - http://www.fullfatrr.com/forum/topic6133.h...ddle+shift
Post #449535 30th Aug 2017 3:12pm
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
It's not possible on the TdV8 6-speed ... as I found out the hard way!!! Evil or Very Mad
Apparently it's a gearbox hardware issue ... Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #449536 30th Aug 2017 3:20pm
j_rov
Thanks Mick
I shall get it out of my head now then!!! __
Land Rover History:
1976 Series 3 2.25
Post #449538 30th Aug 2017 3:49pm
mzplcg
Really? If it's a true MY10 the box can have a hybrid firmware applied (GAP) which is what I did on my 59 plate Supercharged. This had the ZF 6HP28 box & factory paddles although it wasn't the TDV8, but IIRC the TDV8 on the 10MY (LCD dash is a good indicator) also used the 6HP28.
I believe the older cars had the 6HP26 which can also take paddles (available on the Jag XF since 07) but the canbus was not set up on the FFRR to accommodate this. The 2009 to 2010 change involved a major change to CANBUS, hence the 2010 cars can be done (I think)
The thing I found out is that the change from the 3.6 to the 4.4 TDV8 was done in 2 stages. One stage saw the arrival of a LCD dash and some rather wooden brakes but kept the 3.6 and had no shift paddles. This update did include the change of CANBUS standard.
The we saw the arrival of the 4.4 with the 8 speed box and paddles, and some better 6 pot brakes.
Might be worth checking with Bodsy or the GAP boys. They will know 100%
Post #449586 31st Aug 2017 8:10am
millerj90
If I understood the article I posted. The guy re engineered the paddles to operate as simple switches, replicating the action of the gear shift in manual sport mode.
Post #449590 31st Aug 2017 8:25am
mzplcg
And that would work on the older cars which don't have CANBUS support for paddles, I recall reading the same thing, probably on here. But the 2010MY update saw CANBUS go to 11 bit from the older 29 bit system.
If (after removing the airbag) the steering wheel has the connector for the paddles, unless a later wheel has been fitted the odds are that it can be done.
Post #449592 31st Aug 2017 8:34am
j_rov
Quite the quandary then! Will it be easily recognisable that the connections are there if i remove the airbag?
I'd like them for more gear control off-road than for sporty driving. __
Land Rover History:
1976 Series 3 2.25
Post #449596 31st Aug 2017 9:12am
mzplcg
Do you have the digital LCD dash? If yes you will be able to retrofit paddles. If you have the older analogue instrument pack you have the older 29 bit CANBUS which cannot accommodate paddles.
Under the airbag there will be a 4 pin connector which the paddles plug into.
Post #449600 31st Aug 2017 10:37am
from memory i'm sure you are automatically restricted to low gears in off road height so the paddles are a bit pointless for off road use, in fact they are totally pointless for a large suv like the FF... ... - .- -.
Post #449601 31st Aug 2017 10:41am
Oh I don't know Stan there's at least some point on-road. Part of the purpose of the car is to make us grin. Flapping down a couple of cogs in the SC before flooring it to pass slower traffic never fails to make me grin...... Mike - MPx
Post #449607 31st Aug 2017 12:04pm
..again , i find the kickdown/acceleration adequate on my previous 4.2 SC and now my 4.4 tdv8 .. ... - .- -.
Post #449608 31st Aug 2017 12:14pm
j_rov
I have the LCD dash etc and the 6hp26 box according to TOPIX.
Regarding off roading, I think paddles are very useful, especially for ascending under control while keeping both hands on the wheel. __
Land Rover History:
1976 Series 3 2.25
Post #449611 31st Aug 2017 12:31pm
j_rov
Thanks, sounding more positive... __
Land Rover History:
1976 Series 3 2.25
Post #449612 31st Aug 2017 12:32pm
