Home > Maintenance & Mods (L322) > Which IID tool to buy
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys I'm looking at buying an IID tool to check CCF files to see if I can enable closing of windows with key remote as this function is not enabled on my vehicle 2006 Vogue SE also I want to reset inspection indicator on dash. Which ones do you recommend to do this please.
Cheers
Jay
Post #449037 25th Aug 2017 9:18am
pretty sure it's only the bluetooth version available now...ask dan @ duckworths for a price in his section..
you might find a used non BT version which will be cheaper . ... - .- -.
Post #449038 25th Aug 2017 9:32am
jaysta10k
Thanks Stan I was thinking the Gap Bluetooth or the Bearmach Hawkeye.
Post #449040 25th Aug 2017 9:36am
jaysta10k
Have you got a link to Dan@Duckworths please save searching through all users.
Cheers
Post #449041 25th Aug 2017 9:41am
davidsmith1307
If it is just for this vehicle then the Gap BT is far superior. If you have a number of different LR vehicles of different models then the Hawkeye Total makes financial sense but is less capable.
Post #449047 25th Aug 2017 10:12am
jaysta10k
Thanks mate the Gap IID Bluetooth it is then👍
Post #449049 25th Aug 2017 10:15am
Billaboard
United Kingdom 2004 Range Rover Vogue Td6 Baltic Blue
Cheers
I just got a quote from Dan by clicking on "Sponsors" at the top of this page and following the Duckworth advert.
They only do the BT version. The price seemed competitive.
As far as I can tell the killer for me with the BT version is the requirement to have an Apple or posh Android device to read it. Old 110 2.3 Petrol ???? - ????
Old 110 200tdi ???? - 2004
1996 Discovery 300tdi 2004 - 2015 met fiery end being welded
2004 JEEP Grand Cherokee 2015 - 2017
2004 L322 Td6 2017 -
Post #449055 25th Aug 2017 11:14am
jaysta10k
Cheers I will look into into 👍 Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #449057 25th Aug 2017 11:40am
RR2008HSE
The IID is great. Yeah, it's all BT now, but if you don't intend to use it very much, the non-BT makes an attractive second hand purchase.
Post #449121 25th Aug 2017 10:38pm
Topbrass
England 2005 Range Rover Vogue Td6 Zambezi Silver
Hi does anyone use/hve a snapon solus pro ?if so are they more for the Joe 90s
Or a novice like me.Are they straight forward to use ? Would an icarsoft do more
or less the same job Any feedback would much appreciate. Bow down
Post #449153 26th Aug 2017 1:55pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
All strapon diagnostics are poo!
IID tool are good I have both, bt one much better
Post #449157 26th Aug 2017 2:12pm
jaysta10k
Ordered my BT IID off Dan at Duckworths is there a way to disable land enable the engine immobiliser with this tool? Also I'm looking at buying a new flip key as I have the old style lollipop keys. I am aware that I will need to have the transponder reprogrammed to start the car but I'm not going back to the stealers again as I bought two new keys last year a case of having to no choic it cost me £400 and wasn't aware of the the syncing procedure etc that's available to view on here!
Cheers
J Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #450257 8th Sep 2017 9:04am
go on the GAP site and theres a drop down menu where you can see what the iidtool can do,
https://www.gap-diagnostic.com/products/iidtool/
[engine immobiliser = no] ... - .- -.
Post #450258 8th Sep 2017 9:11am
